When configuring STM32F107RC FreeRTOS, the interrupt CALLBACK function is not called
‎2023-09-10 11:20 PM
Hello.
I have some questions while testing a product using the 107MCU.
As the title suggests, when I set up FreeRTOS and create a task, the commonly used callback functions cannot be called:
void HAL_SPI_RxCpltCallback(SPI_HandleTypeDef *hspi) void HAL_SPI_TxCpltCallback(SPI_HandleTypeDef *hspi) void HAL_SPI_TxRxCpltCallback(SPI_HandleTypeDef *hspi) void HAL_GPIO_EXTI_Callback(uint16_t GPIO_Pin)
If I remove the task creation function, it operates normally.
Do you know why this is happening?
Thank you.
‎2023-09-11 6:38 AM
Program bug of some sort.
Perhaps the starting SPI functions never get called. Perhaps chip resets due to corrupted stack.
‎2023-09-11 6:50 AM
Hello @User.72,
You may want to check your interrupt priorities, which means it can be a higher priority task blocking SPI, GPIO callbacks
