USBPD GUI interface not working
‎2025-03-11 8:43 PM - last edited on ‎2025-03-17 3:41 AM by Andrew Neil
I have designed a custom board using STM32G431CB and TCPP03. I am trying to make as a sink device. I followed this video : https://youtu.be/cbdFHmMOMwk?si=GqcDTJeDxTsrFDiG
I have successfully generated and compiled the code. Also, i enabled the GUI interface and TRACE. I am able to get the trace messages in STM32CubeMonUCPD. But unable to see the GUI interface board port, I tried refreshing it several times but no luck .
Please help.
Thanks in advance.
STM32G4 Series
UCPD
‎2025-03-26 5:55 AM
Hi @RJain.1
Only STMicroelectronics COM ports are authorized.
In your specific case of a USB UART converter that appears as a COM port to the PC, it is excluded from the list of potential COM ports by the STM32CubeMonitor-UCPD tool. Otherwise, any competitor could use our tool.
‎2025-03-17 3:20 AM
Hi @RJain.1
Did you ensure that SysTick is initialized correctly ? Please attach .cpd file to dive further.
‎2025-03-21 7:32 AM - edited ‎2025-03-21 7:34 AM
Hi @FBL ,
Yes, I have checked systick is working as expected. I am able to get the traces as shown below:
I am unable to get the .cpd file, just captured the traces in UCPD monitor. I am using monitor - UCPD 1.4.0
I have attached my .ioc file.
Please check the configurations.
I am stuck with the project, I just want to access the GUI Interface to get the SINK configuration. please help.
Thanks,
‎2025-03-22 10:26 PM
I can get the trace and GUI Interface by connecting the UART wires to ST-link UART, but why an ordinary USB to UART converter like CP2102 module cannot display the GUI Interface, only showing traces!!
‎2025-03-25 3:35 AM
Hi @RJain.1
You can save the trace by simply clicking on save trace.
Check demo implementation and UART configured for GUI interface as a reference.
‎2025-03-25 9:36 AM
Hi @FBL ,
Please check my above post:
‎2025-03-26 5:55 AM
Hi @RJain.1
‎2025-03-26 8:09 AM
Okay, got it.
Thanks!!
