USB audio type I IEEE_FLOAT descriptor
‎2023-02-15 9:18 AM
Hi all,
I am using a STM32H7 and I implemented a composite usb device (CDC + AUDIO recording) using IAD interface descriptor.
I can successfully configure the audio interface as type I PCM (I tested both 16 and 32 bit), but if I try to configure the audio as type I IEEE_FLOAT windows does not recognize the microphone (the device is still present in device manager under 'sound devices', but there is no input device under 'Audio inputs and outputs'.
I just changed the wFormatTag field of the descriptor, leaving the bSubFrameSize=4 and bBitResolution=32.
Have I to change something else?
Thank you in advance,
regards
Arianna
‎2023-02-28 10:10 AM
Hi @AGhez​
It seems that windows USB audio 1.0 drivers does not support IEE_FLOAT
you need to switch to audio 2.0 class it is noted in microsoft documentation that audio 2.0 driver support IEE_FLOAT
‎2023-02-27 5:39 AM
Hi , @AGhez​
I suggest to change the PID of device.
‎2023-02-27 8:38 AM
Hi @mohamed.ayed​ ,
thank you for your reply, but I tried with no success!
Do you have any other suggestions?
thanks
Hi @AGhez​
‎2023-03-01 12:22 AM
Hi @mohamed.ayed​ ,
thank you for your reply! I read these articles but it wasn't so clear for me: "All Type I formats" for me means also IEEE_FLOAT, as it is reported in the USB AUDIO 1.0 specifications under the type I supported formats..
But since in the second article you linked the IEEE_FLOAT format is explicitly mentioned probably you are right.
Can you confirm me that there are not ST examples for USB AUDIO 2.0?
Thank you again,
regards
Arianna
‎2023-03-01 5:14 AM
Hi @AGhez​ ,
actually ST USB lib support only audio class 1.0 but USBX (AzureRTTOS) middleware support both Audio 1.0 and audio 2.0 and we don't have an example audio 2.0 until now.
‎2023-03-01 3:18 PM
The link you gave:
All Type I formats (except 8-bit signed PCM)
It took me a minute to find out...
https://www.usb.org/sites/default/files/frmts10.pdf
2.2.6 Supported Formats
The following paragraphs list all currently supported Type I Audio Data Formats.
2.2.6.3 IEEE_FLOAT Format
‎2023-03-13 2:59 AM
I got my device enumerated in USB Audio 2.0 (just enumerated, it is not really working), but I am experiencing the same issue: with format PCM the microphone appears between the recording devices, changing the format to FLOAT makes the microphone to not appear!
Any other clue?
Thank you,
regards
Arianna
‎2023-03-13 4:47 AM
why you insist on float ? this is very unusual for audio device, because standard is pcm or I2S in 16/24/32 bit (float not possible) ; these are the data formats, codecs use for audio in/out .
‎2023-03-13 4:50 AM
I need 32 bit AND exclusive access: WASAPI does not support exclusive access with PCM 32 bits, but only with 8 and 16 bits, or with float, so that's why I am struggling with float..
