stm32u575rit6 qspi driver
Prakash_Raj1994
I am using Cubemax version 6.8.0 for driver generation after configuring QSPI i am not able see any QSPI related driver in stm32ide Version: 1.12.0
Prakash R
5 REPLIES 5
Prakash_Raj1994
please let me to know any example related to stm32u575rit QSPI
Prakash R
FBL
Hello @Prakash_Raj1994 and welcome to ST Community,
Would you provide more details about the use case? your hardware configuration? the external memory/device used?
For instance, OSPI examples are provided, so you can use them and configure your QSPI target.
I'm out of offce with limited access to my emails.
Happy New Year!
hello,
W25Q16JVZPIQ this is flash memory i am interfacing with stm32u575rit6.. I configure QSPI driver generated for ospi.  can you give any example to get device id.
regards,
Prakash R
Hello again @Prakash_Raj1994
Unfortunately, we cannot provide all the examples. You can try implementing it yourself. If you face any issue, we are here to help.
You need to check the datasheet first.
Happy New Year!
Example of READID command dispatch on STM32U5 OCTOSPI to QSPI Winbond / Micron / Macronix NOR Flash devices.  https://github.com/cturvey/stm32extldr/blob/main/ospi_qspi_readid.c
