2021-08-16 12:12 PM
Hi, I have STM32L496 and use Freertos 10.2.
Everything is fine, but I would like read data from queue without removing from the queue. I discovered function xQueuePeek() but I dont know how to use it if I can read specific item from Queue. For example I can check first and second item. Peek() function return only first item.
please help thank you
2021-08-23 7:10 AM
Hello @lorant124 ,
You can find in this reference all the details about the xQueuePeek() function with an example.
I hope this is helpful.
BeST Regards,
Walid
2021-08-23 7:10 AM
Hello @lorant124 ,
BeST Regards,
Walid
