STM32H523RCT6 goes into HARDFAULT handler/NMI handler
DeepakKumar
Hello ST Team,
                             Currently i am using STM32H523RCT6 mcu for one of my application. Some times mcu goes into "hardfault handler/nmi handler". Can you suggest what will be reasons behind that problem.
Thanks with Regards
DEEPAK
SofLit
Your description does not provide sufficient information. Moreover Hardfault, it's not obvious to tell you the origin of it so need to debug it yourself.
See this article: https://community.st.com/t5/stm32-mcus/how-to-debug-a-hardfault-on-an-arm-cortex-m-stm32/ta-p/672235
The only origin that I can tell you about this Hardfault on H5 product is the following: https://community.st.com/t5/stm32-mcus/how-to-avoid-a-hardfault-when-icache-is-enabled-on-the-stm32h5/ta-p/630085
It could be something related to ECC error see: https://community.st.com/t5/stm32-mcus-products/stm32h5-ecc-errors-and-icache-invalidation/td-p/683375
PS: This is a collaborative space. So please be polite in your reply. Otherwise, it will be reported as inappropriate and you will be permanently blacklisted from my help/support.
1 REPLY 1
SofLit
