STM32F769-DISCO Fatfs not working with SRAM1 and SRAM2 configuration.
tushar_tp
Hardware : STM32F769-DISCO
Compiler: Atollic 9.3.0
I am trying to merge the Fatfs with mbedtls example from cube 1.15
mbedtls has tx and rx buffers at SRAM2 region.
Fatfs sample program fails to write and read a file.
Can anyone look at the linker script and MPU_Config() function in main.c if I am doing it correctly.
I am attaching the project folder.
PS: simple fatfs program without any linker file modification works OK.
Thanks,
Tushar
Hello Clive,
I managed to get it working on the SRAM1 and SRAM2 configuration.
Changed the function to this
static void MPU_Config(void)
 MPU_Region_InitTypeDef MPU_InitStruct;
 /* Disable the MPU */
 HAL_MPU_Disable();
 MPU_InitStruct.Enable = MPU_REGION_ENABLE;
 MPU_InitStruct.BaseAddress = 0x20020000;
 MPU_InitStruct.Size = MPU_REGION_SIZE_512KB;
 MPU_InitStruct.AccessPermission = MPU_REGION_FULL_ACCESS;
 MPU_InitStruct.IsBufferable = MPU_ACCESS_NOT_BUFFERABLE;
 MPU_InitStruct.IsCacheable = MPU_ACCESS_CACHEABLE;
 MPU_InitStruct.IsShareable = MPU_ACCESS_NOT_SHAREABLE;
 MPU_InitStruct.Number = MPU_REGION_NUMBER0;
 MPU_InitStruct.TypeExtField = MPU_TEX_LEVEL0;
 MPU_InitStruct.SubRegionDisable = 0x00;
 MPU_InitStruct.DisableExec = MPU_INSTRUCTION_ACCESS_ENABLE;
 HAL_MPU_ConfigRegion(&MPU_InitStruct);
 /* Configure the MPU as Normal Non Cacheable for Ethernet Buffers in the SRAM2 */
 MPU_InitStruct.BaseAddress = 0x2007C000;
 MPU_InitStruct.Size = MPU_REGION_SIZE_16KB;
 MPU_InitStruct.IsCacheable = MPU_ACCESS_NOT_CACHEABLE;
 MPU_InitStruct.IsShareable = MPU_ACCESS_SHAREABLE;
 MPU_InitStruct.Number = MPU_REGION_NUMBER1;
 MPU_InitStruct.TypeExtField = MPU_TEX_LEVEL1;
 /* Configure the MPU as Device for Ethernet Descriptors in the SRAM2 */
 MPU_InitStruct.Size = MPU_REGION_SIZE_256B;
 MPU_InitStruct.IsBufferable = MPU_ACCESS_BUFFERABLE;
 MPU_InitStruct.Number = MPU_REGION_NUMBER2;
 /* Enable the MPU */
 HAL_MPU_Enable(MPU_PRIVILEGED_DEFAULT);
and uncomment the ENABLE_SD_DMA_CACHE_MAINTENANCE in the sd_diskio.c
Thanks,
Tushar
4 REPLIES 4
You've got 128KB of DTCMRAM, use that for buffering, avoids all the caching issues with DMA.
Polled operation shouldn't have issues, well at least beyond the overrun/underrun and interrupt ones.
Otherwise you've got to use cache management. ST has some workable "ByAddr" sample drivers under the FatFs middleware directories.
tushar_tp
Hello Clive,
128KB would not be enough as I would need 160KB of heap for my FreeRTOS. as my final application would need lots of RAM.
Can you please comment if I can use the fatfs on SRAM1 ? is there any modification needed in my project files?
Tushar Patel
You can use whatever memory you want, I'm suggesting using the DTCMRAM for buffers used for fread/fwrite operations surrounding SDIO/FATFS, which for efficiencies sake really should be sector/cluster aligned.
See
STM32Cube_XYZ\Middlewares\Third_Party\FatFs\src\drivers\sd_diskio_dma_rtos_template.c
If it is not working, then clearly.
Hello Clive,
 HAL_MPU_Disable();
Thanks,
Tushar
