Stm32f429
‎2024-01-25 4:21 AM - edited ‎2024-01-25 4:24 AM
Hi all
I'm want to send a string from one stm32 to another stm32 to blink an led on it I'm using uart polling method to do that.
The communication happens and led blinks only if I press the Reset button once I switch off and on power supply. What should be done if I want continuous communication.
‎2024-01-25 6:26 AM
Still lacking detail - that shows us nothing other than BOOT0 is connected to ground.
How about posting the code you have?
Use this button to properly post source code:
It opens up a window into which you copy & paste your code.
To get that extra row of icons, press this button:
‎2024-01-25 4:47 AM
@harry123 wrote:What should be done if I want continuous communication.
Put it in an endless loop
‎2024-01-25 4:54 AM
is this a custom board? BOOT0 pulled Low?
Try to provide some more detail rather than symptom.
‎2024-01-25 5:25 AM
Yes it's a custom board and. Boot0 is pulled low.
‎2024-01-25 6:26 AM
‎2024-01-25 9:15 PM
/* USER CODE BEGIN Header */
* @file : main.c
* @brief : Main program body
* @attention
* Copyright (c) 2024 STMicroelectronics.
* All rights reserved.
/* USER CODE END Header */
#include "main.h"
#include "string.h"
/* Private includes ----------------------------------------------------------*/
/* USER CODE END Includes */
/* USER CODE BEGIN PTD */
/* USER CODE END PTD */
/* USER CODE BEGIN PD */
/* USER CODE END PD */
/* USER CODE BEGIN PM */
/* USER CODE END PM */
UART_HandleTypeDef huart8;
UART_HandleTypeDef huart1;
/* USER CODE BEGIN PV */
/* USER CODE END PV */
static void MX_USART1_UART_Init(void);
static void MX_UART8_Init(void);
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
/* Private user code ---------------------------------------------------------*/
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
* @brief The application entry point.
* @retval int
int main(void)
/* USER CODE BEGIN 1 */
/* USER CODE END 1 */
HAL_Init();
/* USER CODE BEGIN Init */
/* USER CODE END Init */
SystemClock_Config();
/* USER CODE BEGIN SysInit */
/* USER CODE END SysInit */
MX_GPIO_Init();
MX_USART1_UART_Init();
MX_UART8_Init();
/* USER CODE BEGIN 2 */
uint8_t tx[3]="ADC";
/* USER CODE END 2 */
/* Infinite loop */
/* USER CODE BEGIN WHILE */
while (1)
/* USER CODE END WHILE */
/* USER CODE BEGIN 3 */
HAL_UART_Transmit(&huart8,tx,3,100);
HAL_Delay(1000);
/* USER CODE END 3 */
* @brief System Clock Configuration
* @retval None
void SystemClock_Config(void)
__HAL_RCC_PWR_CLK_ENABLE();
__HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
RCC_OscInitStruct.HSEState = RCC_HSE_ON;
RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
RCC_OscInitStruct.PLL.PLLM = 4;
RCC_OscInitStruct.PLL.PLLN = 180;
RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
RCC_OscInitStruct.PLL.PLLQ = 3;
Error_Handler();
/** Activate the Over-Drive mode
if (HAL_PWREx_EnableOverDrive() != HAL_OK)
Error_Handler();
RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;
RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_5) != HAL_OK)
Error_Handler();
* @brief UART8 Initialization Function
* @PAram None
* @retval None
/* USER CODE BEGIN UART8_Init 0 */
/* USER CODE END UART8_Init 0 */
/* USER CODE BEGIN UART8_Init 1 */
/* USER CODE END UART8_Init 1 */
huart8.Instance = UART8;
huart8.Init.BaudRate = 115200;
huart8.Init.WordLength = UART_WORDLENGTH_8B;
huart8.Init.StopBits = UART_STOPBITS_1;
huart8.Init.Parity = UART_PARITY_NONE;
huart8.Init.Mode = UART_MODE_TX_RX;
huart8.Init.HwFlowCtl = UART_HWCONTROL_NONE;
huart8.Init.OverSampling = UART_OVERSAMPLING_16;
if (HAL_UART_Init(&huart8) != HAL_OK)
Error_Handler();
/* USER CODE BEGIN UART8_Init 2 */
/* USER CODE END UART8_Init 2 */
* @brief USART1 Initialization Function
* @PAram None
* @retval None
/* USER CODE BEGIN USART1_Init 0 */
/* USER CODE END USART1_Init 0 */
/* USER CODE BEGIN USART1_Init 1 */
/* USER CODE END USART1_Init 1 */
huart1.Instance = USART1;
huart1.Init.BaudRate = 115200;
huart1.Init.WordLength = UART_WORDLENGTH_8B;
huart1.Init.StopBits = UART_STOPBITS_1;
huart1.Init.Parity = UART_PARITY_NONE;
huart1.Init.Mode = UART_MODE_TX_RX;
huart1.Init.HwFlowCtl = UART_HWCONTROL_NONE;
huart1.Init.OverSampling = UART_OVERSAMPLING_16;
if (HAL_UART_Init(&huart1) != HAL_OK)
Error_Handler();
/* USER CODE BEGIN USART1_Init 2 */
/* USER CODE END USART1_Init 2 */
* @brief GPIO Initialization Function
* @PAram None
* @retval None
/* USER CODE BEGIN MX_GPIO_Init_1 */
/* USER CODE END MX_GPIO_Init_1 */
/* GPIO Ports Clock Enable */
__HAL_RCC_GPIOC_CLK_ENABLE();
__HAL_RCC_GPIOH_CLK_ENABLE();
__HAL_RCC_GPIOA_CLK_ENABLE();
__HAL_RCC_GPIOG_CLK_ENABLE();
__HAL_RCC_GPIOE_CLK_ENABLE();
/*Configure GPIO pin Output Level */
HAL_GPIO_WritePin(GPIOG, GPIO_PIN_14, GPIO_PIN_RESET);
/*Configure GPIO pin : PG14 */
GPIO_InitStruct.Pin = GPIO_PIN_14;
GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
HAL_GPIO_Init(GPIOG, &GPIO_InitStruct);
/* USER CODE BEGIN MX_GPIO_Init_2 */
/* USER CODE END MX_GPIO_Init_2 */
/* USER CODE BEGIN 4 */
/* USER CODE END 4 */
* @brief This function is executed in case of error occurrence.
* @retval None
void Error_Handler(void)
/* USER CODE BEGIN Error_Handler_Debug */
/* User can add his own implementation to report the HAL error return state */
__disable_irq();
while (1)
/* USER CODE END Error_Handler_Debug */
#ifdef USE_FULL_ASSERT
* @brief Reports the name of the source file and the source line number
* where the assert_param error has occurred.
* @PAram file: pointer to the source file name
* @PAram line: assert_param error line source number
* @retval None
void assert_failed(uint8_t *file, uint32_t line)
/* USER CODE BEGIN 6 */
/* User can add his own implementation to report the file name and line number,
ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
/* USER CODE END 6 */
#endif /* USE_FULL_ASSERT */
* @file : main.c
* @attention
#include "main.h"
#include "stdio.h"
#include "string.h"
ADC_HandleTypeDef hadc1;
#define START_ADC_STRING "ADC"
#define RX_BUFFER_SIZE 3
char rx_buffer[RX_BUFFER_SIZE];
volatile uint8_t rx_index = 0;
static void MX_ADC1_Init(void);
void Blink_LED(void) {
for(int i=0;i<5;i++)
HAL_GPIO_WritePin(GPIOG, GPIO_PIN_14, GPIO_PIN_SET);
HAL_Delay(100);
HAL_Delay(100);
HAL_Delay(1000);
HAL_UART_Transmit(&huart1,rx_buffer,strlen(rx_buffer),100);
* @retval int
int main(void)
HAL_Init();
MX_GPIO_Init();
MX_UART8_Init();
MX_ADC1_Init();
/* Infinite loop */
while (1)
if (HAL_UART_Receive(&huart8, (uint8_t *)&rx_buffer[rx_index], 1, 100) == HAL_OK) {
// Check for the desired string
if (strstr(rx_buffer, START_ADC_STRING) != NULL) {
Blink_LED();
// Increment the index
rx_index++;
// Reset the receive buffer if it's full
if (rx_index >= RX_BUFFER_SIZE) {
memset(rx_buffer, 0, RX_BUFFER_SIZE);
rx_index = 0;
* @retval None
Error_Handler();
Error_Handler();
Error_Handler();
* @brief ADC1 Initialization Function
* @PAram None
* @retval None
/* USER CODE BEGIN ADC1_Init 0 */
/* USER CODE END ADC1_Init 0 */
ADC_ChannelConfTypeDef sConfig = {0};
/* USER CODE BEGIN ADC1_Init 1 */
/* USER CODE END ADC1_Init 1 */
/** Configure the global features of the ADC (Clock, Resolution, Data Alignment and number of conversion)
hadc1.Instance = ADC1;
hadc1.Init.ClockPrescaler = ADC_CLOCK_SYNC_PCLK_DIV4;
hadc1.Init.Resolution = ADC_RESOLUTION_12B;
hadc1.Init.ScanConvMode = DISABLE;
hadc1.Init.ContinuousConvMode = DISABLE;
hadc1.Init.DiscontinuousConvMode = DISABLE;
hadc1.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
hadc1.Init.ExternalTrigConv = ADC_SOFTWARE_START;
hadc1.Init.DataAlign = ADC_DATAALIGN_RIGHT;
hadc1.Init.NbrOfConversion = 1;
hadc1.Init.DMAContinuousRequests = DISABLE;
hadc1.Init.EOCSelection = ADC_EOC_SINGLE_CONV;
if (HAL_ADC_Init(&hadc1) != HAL_OK)
Error_Handler();
/** Configure for the selected ADC regular channel its corresponding rank in the sequencer and its sample time.
sConfig.Channel = ADC_CHANNEL_2;
sConfig.Rank = 1;
sConfig.SamplingTime = ADC_SAMPLETIME_3CYCLES;
if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK)
Error_Handler();
/* USER CODE BEGIN ADC1_Init 2 */
/* USER CODE END ADC1_Init 2 */
* @PAram None
* @retval None
Error_Handler();
* @PAram None
* @retval None
Error_Handler();
* @PAram None
* @retval None
* @retval None
__disable_irq();
while (1)
* @retval None
‎2024-01-26 7:52 AM - edited ‎2024-01-26 8:02 AM
Well, that code should transmit continuously in a loop.
Does it run under debug?
BTW: you've marked by previous reply as The Solution - but I don't think it solves your problem?
‎2024-01-26 11:26 PM - edited ‎2024-01-26 11:27 PM
Yes the code runs under debug once the supply is made off and on the code works after i press the reset button on any of the two board.
BTW: you've marked by previous reply as The Solution - but I don't think it solves your problem? I clicked it by mistake.
‎2024-01-27 5:08 AM - edited ‎2024-01-27 5:10 AM
@harry123 wrote:Yes the code runs under debug once the supply is made off and on the code works after i press the reset button on any of the two board.
I mean if you run it within the debugger in the IDE - does the restart button within the debugger successfully restart the code?
@harry123 wrote:I clicked it by mistake.
Once you've clicked it, you have the option to undo that ...
‎2024-01-28 9:38 PM
Yes it works
