STM32F103 USB Packet Memory
‎2020-04-30 9:31 AM
Writing a USB Driver using a China manufactured "Blue Pill"
I'm not using HAL or Cube.
I wrote some code to test the USB cell and my understanding of how it works.
I tested the USB's Packet memory which is 512 bytes organized as 256 words. The Application accesses this memory on 32 bit boundaries (using a DWORD pointer).
I wrote test data to the Packet Memory and then read it out into a ram based array to verify its contents. I have found that single bits are incorrect at many of the Packet Memory locations.
Has anyone else seen this issue?
The Blue Pill is a sub $2 board - are they being built with ST parts that had issues in MFG test?
Any ideas on this issue?
STM32F1 Series
USB
‎2020-05-01 1:41 AM
More probably with counterfeit parts, i.e. chips which are not by ST but are marked falsely so.
https://www.eevblog.com/forum/microcontrollers/cheap-bluepill-very-likely-it-has-fake-stm32-right/
> I wrote test data
How exactly? I haven't tried on 'F1, but on 'F0 writing by bytes does not work
https://community.st.com/s/question/0D50X00009XkaAs/f042-usb-usb-buffer-not-writable-bytewise
‎2020-05-01 1:56 AM
The PMA is arranged as 256 16-bit words that need to be written on 32-bit foundries. I used a 32-bit pointer to write/read 16-bit values to the 256 locations in the PMA - exactly the same way HAL or many drivers do it.
‎2020-05-01 2:00 AM
Don't you have a board with known genuine STM32F103 to compare?
‎2020-05-01 2:44 AM
No I don't. I usually design my own boards using larger micros. I needed to cheap little board to build a heated box so I purchased the Blue Pill. I wanted to get into USB so I used the STM32F103 - Blue Pill - as the test board for writing my own USB driver. After working with it, I don't think I would choose that device for an embedded application - implementation seems quirky when control/status bits need to be changed by "toggle" instead of standard - set/clear.
I'll use the board for the "Bread Proofer Box"but will not proceed with the USB development.
I purchased a "Black Pill" - STM32F411 - I'll use THAT board to develop my USB understanding. The USB FS implementation appears to be much better than that of the STM32F103.
‎2020-05-02 12:58 AM
Honestly I don't understand this masochism with deficient clones of the old STM32F1 and boards without debugger, when there is a NUCLEO-G431KB with ST-LINK on board.
https://octopart.com/nucleo-g431kb-stmicroelectronics-102284322
‎2020-05-02 4:25 AM
Just to clarify - I do embedded design for a living. A Real J-Link tool was used in the investigation of this issue with this Blue Pill.
