2021-06-10 04:07 AM
Im trying to establish an I2C communication between stm32f446nucleo board and stl32f469i disco board,
I flashed the stm32f446-nucleo I2C master code example from cubeF4stm32f446 into an stm32f446 nucleo board and the slave I2C code example from cubeF4-stm32f496i disco into an stm32f469i disco board,
As a result i get an indication ( LedToggle ) that there was an error during communication,
Is what I did correct ?
2021-06-16 04:41 AM
Hi @Malek Mahar ,
If problem is still there, I have some proposals/questions:
-Amel
2021-06-10 06:54 AM
Have you tried to debug, do you see something on the I2C lines ?
2021-06-16 02:42 AM
Yes I did, the problem was related to the hardware part, SDA and SCL not changing from HIGH to LOW,
thank you for your answer
2021-06-16 04:41 AM
Hi @Malek Mahar ,
-Amel
2021-06-16 10:27 AM
hI @Amel NASRI ,
https://community.st.com/s/question/0D53W00000sqQt9SAE/i2c-between-two-stm32-boards-not-working
this is a more detailed post just I have just published,
thank you,
