Shared RAM memory from boot to firmware
RComa.1
Hello everye one, i have a customized bootloader and firmware, i need pass som argument from the first one to the last one, in both project, at linker scripr file i have the following:
MEMORY
  RAM    (xrw)    : ORIGIN = 0x20000000,   LENGTH = 12K
  SHARED	(xrw)	: ORIGIN = 0x20002000, LENGTH = 8K
  FLASH    (rx)    : ORIGIN = 0x8009C00,   LENGTH = 25K
SECTIONS
 .shared_mem :
  . = ALIGN(4);
  __shared_mem_start__ = .;
  	*(.shared_mem.key)
  	*(.shared_mem.ID)
    *(.shared_mem*)
  __shared_mem_end__ = .;
  } > SHARED
as you can see i created a SHARED area and shared_mem into, and the application project has the same defined area, and then in the main.c files has thes two lines
__attribute__((section(".shared_mem.key"))) volatile uint32_t VERSION[20];
__attribute__((section(".shared_mem.ID"))) volatile uint32_t ID[20];
if i compile, everything is okay, but when i try to write something in VERSION from the bootloader, the file's size step up a lot, like 300Kb, so if i code the following:
VERSION[0] = 1;
it makes file.bin increase its size a lot and then i cannot flash the MCU because of its size.
Do know someone what's going on?
thanks a lot in advance.
4 REPLIES 4
add the (NOLOAD) attribute to .shared_mem output section
.shared_mem (NOLOAD):
RComa.1
Hello, nice the problem has been solved, now the problem is, when bootloader jumps to app, HAL_Delay seems doesn't work, at the begin i put:
SCB->VTOR = 0x8009C00;
__enable_irq();
but it doesn't work yet i am not sure whether new memory are has nothing to do with this problem...
Do you transfer control from an interrupt or callback routine?
Check that the Systick interrupt has been enabled and that it's being called.
Hi there, i hope you fine! i use this code to jump from the boot to the app:
typedef void (*pFunction)(void);
void jumpApp(){
        uint32_t jumpAddress;
	pFunction jump_to_app;
	jumpAddress = *(uint32_t*) (FLASH_APP_ADDR + 4);
	jump_to_app = (pFunction)jumpAddress;
    __HAL_RCC_GPIOC_CLK_DISABLE();
    __HAL_RCC_GPIOD_CLK_DISABLE();
    __HAL_RCC_GPIOB_CLK_DISABLE();
    __HAL_RCC_GPIOA_CLK_DISABLE();
	HAL_RCC_DeInit();
	HAL_DeInit();
	SysTick->CTRL = 0;
	SysTick->LOAD = 0;
	SysTick->VAL = 0;
	 __disable_irq();
	 __HAL_SYSCFG_REMAPMEMORY_SYSTEMFLASH();
	__set_MSP(*(uint32_t*)FLASH_APP_ADDR); //Stack
	jump_to_app();
How can i enable the systick interrupt?
