Selected test cannot be mapped to a symbol name and grayed code .
dhs
Senior
Despite the USE_STATIC_ALLOCATION is defined to 1, code is showed in gray, I added a break point on gray section and stoped well.
Down below the sequence to found the path to marco definition:
app_azure_rtos.c include app_azure_rtos.h this include app_azure_rtos_config.h this one has the sentence : #define USE_STATIC_ALLOCATION        1
1 REPLY 1
GBaud.1
I have the same problem when I try to make a project based on STM32U5 evaluation board and enabling the ThreadX middleware.
Is this a bug ?
