run ethercat master on stm32H7 series
gcaif
I want to run ethercat master on stm32H7 series.who know how to do?have example?
W-E
Hello gcaif,
if you did not find a solution for the EtherCAT master meanwhile, you could have a look on the following web page:
https://www.ibv-augsburg.de/en/products/icnet/ethercat-master/
IBV provides an EtherCAT master software which is especially designed for microcontrollers like the STM32H7.
Best regards,
Walter
6 REPLIES 6
W-E
Hello gcaif,
Best regards,
Walter
gcaif
thank you for you reply
WHam.1
I have success to make ECAT Master functioning on STM32F769I-DISC by just using firmware (Without RTOS) based on LWIP Structure With disabling ARP, UDP, TCP functionality.   Refer to my you tube site even though speaking language is Korean language. https://www.youtube.com/watch?v=Ij0igfk4ogU
@WHam.1
Thank you. Better to make your videos in English, so they will be more helpful and increase your audience in your channel ;)
PS:
OK.  Thank you.
I will try to make  by using English in near future even though my English Speaking level is so good. Please  refer to another my  brief you tube even though speaking language is Korean language.
 https://www.youtube.com/watch?v=5v3Tgy0glXs
WHam.1
You can watch my video how ECAT master functioning is working on STM32F769I-DISK board by using LWIP with TCP,UDP,ARP functioning disable and by using RAW packet handling. In this case we don't use the RTOS and just use firmware only. Even though my  English speaking  skill is not good,  I try to introduce by using English.  https://www.youtube.com/watch?v=qFbB_oez4dU
