2019-12-31 03:16 AM
Hi all, Iam trying to send a long payload message in a single buffer (const char*) to Mqtt server. Iam using Lwip Mqtt from http://www.nongnu.org/lwip/2_0_x/group__mqtt.html
It worked with payload that fewer than 232 characters. As we know the limit for mqtt payload lenght is 65536.
I tried to compare the result by publish random data (2898 characters) using mosquitto (installed in my pc), it is successfully done.
Any idea how to solve this problem?
2020-01-03 11:36 PM
has anyone faced the same problem?
or maybe it's a new bug?
i tried it on Nucleo F7 and discovery F4, but still get the same result.
2020-09-28 10:08 PM
Hi, open the header file with name mqtt_opts.h and edit the following sections i.e. 1024 Byte
#define MQTT_OUTPUT_RINGBUF_SIZE 1024
