In stm32h743, in SPI, enabling the EOT IRQ after the other IRQs are enabled makes the SPI ISR to be fired endlessly. Why?
‎2023-03-22 3:02 AM
In stm32h743, in SPI, I have a slave device with interrupts enabled. In particular, I'm enabling all the error interrupts (UDR, OVR, CRCERR, FRE, MODF), and the RXP, TXP and EOTIE interrupts, in that order.
If I enable EOTIE the first of all of them, everything goes fine. If I enable it after the TXP (as above), the SPI ISR gets fired endlessly. I read the SR reg. within it and its value is 0x12 (TXTF and TXP set), which makes sense because I didn't fill the TxFIFO, but I don't see why it fires all the time.
Any idea why this happens?
SPI
STM32H7 Series
‎2023-03-23 5:46 AM
As mentioned by Pavel, you should follow the sequence.
Here is another thread about the same topic SPI EOT interrupt triggered right after SPI enable (st.com)
‎2023-03-22 7:28 AM
Hello @DGast.1​,
I think the screenshot you intended to share is still not attached.
Would you mind adding it for better understanding?
‎2023-03-22 10:43 AM
Sorry, I meant if I enable it as I explained above, that is, after TXP. It's difficult to add the code to explain it as it is enabled within a RTOS' driver.
‎2023-03-22 8:16 PM
The ISR will be re-entered immediately again while the interrupt source is active and unmasked (and the whole peripheral's interrupt is enabled in NVIC). This is how NVIC works.
Duplicate:
‎2023-03-23 5:46 AM
