2023-02-02 6:32 AM
So I Am trying to use the dual regular simultaneous mode with DMA transfer, I tried to use one ADC with the DMA transfer and It works fine but with 2 ADCs I use the function HAL_ADCEx_MultiModeStart_DMA() but the called back function is not actually called so the HAL_ADC_ConvCpltCallback() is not called which means no conversion is happening also the buffer is empty
does anyone have any idea how to fix that?
here is my main.c code:
https://drive.google.com/file/d/1ve5XwGVgaSBvuDYn4lMT79EXxj1-ykCd/view?usp=sharing
2023-02-03 5:41 AM
2023-06-05 6:21 AM
Did you find the solution to this? I am also trying the same. Please let me know if you find it
