How to setup USB-C PD Source using NUCLEO-G491RE with X-NUCLEO-SRC1M1 Extension?
2023-02-08 10:56 AM
I am a newcomer to the ST world- I am working with VW of America and UTK on a senior design project.
I am attempting to setup a USB-C PD source application using a NUCLEO-G491RE Connected to a SRC1M1 extension board. I have tried directly loading the src1M1 example project in x-cube-tcpp (nucleo-g474re/applications/USB_PD/SRC1M1_Source) and following this guide on the wiki. For the wiki project, I applied the correct BSP and adjusted the .extsettings file to point to the correct BSP.
When monitoring stcubemonitor-UCPD, neither stack seems to be responding in the desired manner, and no contract is negotiated.
What further steps should I be taking to set up my USB-C application? I know this is a desired function from ST, so it should be pretty simple.
STM32G4 Series
TCPP
USB
USB-PD
2023-02-09 6:59 AM
Hello @AChin.3
Have you enabled the embedded debug tracer as described here ?
You can also compare the project available on github for NUCLEO-G474RE, it should be similar.
Does something live in the trace window on the right in STM32CubeMonitor-UCPD, following this wiki ?
If yes, can you share the content ?
Nicolas
2023-02-09 10:12 AM
The following is the trace that occurs with my project which followed this wiki.
If I load the src1m1 project from x-cube-tcpp by selecting the ioc file in STM32CubeIDE, building it, and running it, I do not get anything in the trace.
2023-02-09 10:13 AM
During the trace above I did connect a USB-C capable device.
2023-02-10 3:50 AM
Hello @AChin.3 (Community Member)
Please can you try the binary supplied in x-cube-tcpp for scr1M1 on Nucleo-G4 and let us know if it works ?
Pascal
2023-02-10 6:35 AM
When I load that program I do not see my device available on ucpd monitor and I do not see anything on any trace - and there is nothing happening when I plug in the device.
I did identify a potential issue. I connected a dc power supply to cn3, but I connected it to the ground side of the header for a few seconds. I do not believe my supply dissipated any power into the device, but hardware issues are a potential culprit.
2023-02-10 9:25 AM
Hello @AChin.3
Just did the test with a Nucleo STM32G491, with binary from github. (Even if the binary is for a STM32G474...)
Here is what I get in the trace windows of STM32CubeMonitor-UCPD, on startup :
0 DEBUG 0 0 -- BSP_USBPD_PWR_Init --
1 DEBUG 678 0 -- BSP_USBPD_PWR_SetRole : SRC --
2 DEBUG 678 0 -- BSP_USBPD_PWR_SetPowerMode --
3 DEBUG 678 0 -- Low Power --
4 CAD 679 0 USBPD_CAD_STATE_DETACHED
And when I plug a STM32G0-Disco, I get :
11 DEBUG 6895 0 -- BSP_USBPD_PWR_VBUSInit --
12 DEBUG 6895 0 -- BSP_USBPD_PWR_SetPowerMode --
13 DEBUG 6895 0 -- Normal --
14 CAD 6895 0 USBPD_CAD_STATE_ATTACHED_WAIT
15 CAD 7016 0 USBPD_CAD_STATE_ATTACHED
16 NOTIF 7016 0 USBSTACK_START
17 DEBUG 7016 0 ADVICE: USBPD_DPM_Notification:104
18 EVENT 7016 0 EVENT_ATTACHED
19 DEBUG 7016 0 VBUS ON
20 DEBUG 7016 0 -- BSP_USBPD_PWR_VBUSOn --
21 DEBUG 7016 0 -- GDP/GDC setting : SRC --
22 PE 7016 0 PE_SRC_STARTUP
23 NOTIF 7016 0 POWER_STATE_CHANGE
24 DEBUG 7016 0 ADVICE: USBPD_DPM_Notification:90
25 PE 7016 0 PE_SRC_SEND_CAPABILITIES
26 OUT 7018 0 SOP PD3 s:006 H:0x11A1 (id:0, DR:DFP, PR:SRC) SRC_CAPABILITIES DATA: 96900100 Option: [1] Fixed : 5V - 1.5A /
27 OUT 7019 0 SOP PD3 s:006 H:0x11A1 (id:0, DR:DFP, PR:SRC) SRC_CAPABILITIES DATA: 96900100 Option: [1] Fixed : 5V - 1.5A /
28 OUT 7021 0 SOP PD3 s:006 H:0x11A1 (id:0, DR:DFP, PR:SRC) SRC_CAPABILITIES DATA: 96900100 Option: [1] Fixed : 5V - 1.5A /
29 PE 7022 0 PE_SRC_DISCOVERY
30 PE 7172 0 PE_SRC_SEND_CAPABILITIES
31 OUT 7174 0 SOP PD3 s:006 H:0x13A1 (id:1, DR:DFP, PR:SRC) SRC_CAPABILITIES DATA: 96900100 Option: [1] Fixed : 5V - 1.5A /
32 IN 7175 0 SOP s:002 H:0x0201 (id:1, DR:UFP, PR:SNK) GOODCRC
33 NOTIF 7175 0 SRCCAP_SENT
34 DEBUG 7175 0 ADVICE: USBPD_DPM_Notification:15
35 PE 7175 0 PE_SRC_WAIT_REQUEST
36 IN 7177 0 SOP PD3 REQUEST s:006 H:0x1082 (id:0, DR:UFP, PR:SNK) DATA: 96580211 / ObjectPosition:1 / GiveBack:0 / CapabilityMismatch:0 / USBCommunicationCapable:0 / NoUSBSuspend:1 / UnchunkedExtendedMessagesSupported:0
37 OUT 7177 0 SOP s:002 H:0x0161 (id:0, DR:DFP, PR:SRC) GOODCRC
38 PE 7177 0 PE_SRC_NEGOTIATE_CAPABILITY
39 OUT 7177 0 SOP PD3 ACCEPT s:002 H:0x05A3 (id:2, DR:DFP, PR:SRC)
40 IN 7179 0 SOP s:002 H:0x0401 (id:2, DR:UFP, PR:SNK) GOODCRC
41 PE 7179 0 PE_SRC_TRANSITION_SUPPLY
42 NOTIF 7209 0 POWER_STATE_CHANGE
43 DEBUG 7209 0 ADVICE: USBPD_DPM_Notification:90
44 PE 7209 0 PE_SRC_TRANSITION_SUPPLY_EXIT
45 OUT 7211 0 SOP PD3 PS_RDY s:002 H:0x07A6 (id:3, DR:DFP, PR:SRC)
46 IN 7212 0 SOP s:002 H:0x0601 (id:3, DR:UFP, PR:SNK) GOODCRC
47 NOTIF 7212 0 POWER_STATE_CHANGE
48 DEBUG 7212 0 ADVICE: USBPD_DPM_Notification:90
49 NOTIF 7212 0 POWER_EXPLICIT_CONTRACT
You should check for the messages : DEBUG -- BSP_USBPD
Because they are linked to the nucleo-src1m1 shield, and the BSP that controls the TCPP02 which enables the VBUS.
2023-03-07 7:39 AM
I have figured out why my software was not behaving and am now getting good communication between the board and my UCPD monitor/device. However, I am still not charging my device even though I have powered the CN3 header. I have supplied 20V and the D7 LED is on. I have attached my trace. That cycle of src_capablities continues infinitely.
DEBUG 439693 0 -- BSP_USBPD_PWR_VBUSInit -- 0
DEBUG 439693 0 -- BSP_USBPD_PWR_SetPowerMode -- 1
DEBUG 439693 0 -- Normal -- 2
CAD 439693 0 USBPD_CAD_STATE_ATTACHED_WAIT 3
CAD 439815 0 USBPD_CAD_STATE_ATTACHED 4
NOTIF 439815 0 USBSTACK_START 5
DEBUG 439815 0 ADVICE: USBPD_DPM_Notification:104 6
EVENT 439815 0 EVENT_ATTACHED 7
DEBUG 439815 0 VBUS ON 8
DEBUG 439815 0 -- BSP_USBPD_PWR_VBUSOn -- 9
DEBUG 439815 0 -- GDP/GDC setting : SRC -- 10
PE 439815 0 PE_SRC_STARTUP 11
NOTIF 439815 0 POWER_STATE_CHANGE 12
DEBUG 439816 0 ADVICE: USBPD_DPM_Notification:90 13
PE 439816 0 PE_SRC_SEND_CAPABILITIES 14
OUT 439818 0 SOP PD3 s:006 H:0x11A1 (id:0, DR:DFP, PR:SRC) SRC_CAPABILITIES DATA: 96900100
Option:
15
OUT 439819 0 SOP PD3 s:006 H:0x11A1 (id:0, DR:DFP, PR:SRC) SRC_CAPABILITIES DATA: 96900100
Option:
16
OUT 439821 0 SOP PD3 s:006 H:0x11A1 (id:0, DR:DFP, PR:SRC) SRC_CAPABILITIES DATA: 96900100
Option:
17
PE 439822 0 PE_SRC_DISCOVERY 18
PE 439972 0 PE_SRC_SEND_CAPABILITIES 19
OUT 439974 0 SOP PD3 s:006 H:0x13A1 (id:1, DR:DFP, PR:SRC) SRC_CAPABILITIES DATA: 96900100
Option:
20
OUT 439975 0 SOP PD3 s:006 H:0x13A1 (id:1, DR:DFP, PR:SRC) SRC_CAPABILITIES DATA: 96900100
Option:
21
OUT 439977 0 SOP PD3 s:006 H:0x13A1 (id:1, DR:DFP, PR:SRC) SRC_CAPABILITIES DATA: 96900100
Option:
22
PE 439978 0 PE_SRC_DISCOVERY 23
PE 440128 0 PE_SRC_SEND_CAPABILITIES 24
OUT 440130 0 SOP PD3 s:006 H:0x15A1 (id:2, DR:DFP, PR:SRC) SRC_CAPABILITIES DATA: 96900100
Option:
25
OUT 440131 0 SOP PD3 s:006 H:0x15A1 (id:2, DR:DFP, PR:SRC) SRC_CAPABILITIES DATA: 96900100
Option:
26
OUT 440133 0 SOP PD3 s:006 H:0x15A1 (id:2, DR:DFP, PR:SRC) SRC_CAPABILITIES DATA: 96900100
Option:
27
PE 440134 0 PE_SRC_DISCOVERY 28
PE 440284 0 PE_SRC_SEND_CAPABILITIES 29
OUT 440286 0 SOP PD3 s:006 H:0x17A1 (id:3, DR:DFP, PR:SRC) SRC_CAPABILITIES DATA: 96900100
Option:
30
OUT 440287 0 SOP PD3 s:006 H:0x17A1 (id:3, DR:DFP, PR:SRC) SRC_CAPABILITIES DATA: 96900100
2023-03-07 9:57 AM
Hello @AChin.3
In the trace you shared above, I see no "incoming" messages.
Are you sure your sink device is PD capable ? What is the model ?
But still we some messages that VBUS is on. Have you measured the VBUS voltage on the connector ?
Nicolas
2023-03-07 11:02 AM
I have tried a google pixel 6 and a Samsung galaxy s8 as my sink devices. If I use the same cable and device on a different USB charger, it works just fine and charges with USB PD. I have been using a DC power supply, so I am sure the voltage going into cn3 is 20V.
