How to set hardware interrupt priorities in Free RTOS???
l90mehdi
Posted on March 13, 2017 at 13:01
Hello to all.
I am trying to use Free RTOS.
but i do not know how to set hardware interrupt priorities in free RTOS???????
for example i have 3 tasks with different priorities.
also in my code i set or reset pins with external interrupt.but sometimes when external interrupt occurs,my codes does not run correctly and i feel it is a matter of priorities.
please help me .
thank you.
#interrupts-in-free-rtos #interrupts #free-rtos
Nesrine M_O
Lead II
Posted on March 14, 2017 at 13:53
Hi
khastar.mehdi
Any interrupt service routine that uses an RTOS API function must have its priority manually set to a value that is numerically equal to or greater than the configMAX_SYSCALL_INTERRUPT_PRIORITY setting in FreeRTOSConfig.h file. This ensures the interrupt's logical priority is equal to or less than the configMAX_SYSCALL_INTERRUPT_PRIORITY setting.
Please refer to
http://www.st.com/content/ccc/resource/technical/document/user_manual/2d/60/ff/15/8c/c9/43/77/DM00105pdf/files/DM00105pdf/jcr:content/translations/en.DM00105pdf
User manual about Developing Applications on STM32Cube with RTOS.
-Nesrine-
Posted on March 18, 2017 at 13:19
hi Nesrine
I had read this matter.
thank you .
