How to configure FIFO in DMA using nucleo-h745zi
ggowd.1
Hello Team,
I am using DMA in ADC as FIFO mode in NUCLEO-H745ZI board. Tried to configure FIFO mode for DMA, unable to configure. Can you provide details for FIFO configuration.
Regards,
Gagan Gowda
1 REPLY 1
STTwo-32
Hello @ggowd.1
I suggest you take a look at the part 16.3.14 of the RM0399. Also, you can use CubeMX to configure the FIFO mode using CubeMX.
Best Regards.
STTwo-32
