2022-01-11 6:37 AM
2022-01-11 6:40 AM
Question 2 : When the Go command is issued from the master, ( set pointer to start adress of loaded code in slave), what is the core that will start from this adress ( CM4 or CM7 ) ? I dont understant how it is managed.
thank you
