Hello I want select inbuilt USB Microcontroller with Support HID, Cost of Minimum Quantity, Product life cycle, Availability and lead time, Also alternative part number.
Svish.3
Hello I want select inbuilt USB Microcontroller with Support HID, Cost of Minimum Quantity, Product life cycle, Availability and lead time, Also alternative part number. So I hope you will be give me some response on this.
One of the Part number has i selected the part number of that MCU is STM32L151C6T6 . So suggest any other part number or this is best and if it is best then me gives above details like HID etc.
Thank you in advance
1 REPLY 1
Most chips have USB capabilities and can support HID. All chips have a 10-year guarantee, though later families will presumably be supported for longer. There is no "best". Current availability and lead time is fairly awful for everything.
