hardfault when reading the flash
carlesls2
Hello
I think I solved the problem but I do not know why. When I try to access the last address of a page it causes a hardfault.
Unwritten memory can fault.
Unaligned memory reads for doubles fault Cortex-M devices.
CM0(+) device will fault unaligned 16, 32 and 64 bit transactions
Saket_Om
Hello @carlesls2
Could you share more details about your issue and setup please ?
Saket_Om
carlesls2
Solved!
I do not comprehend very well  how I solve it but I far as I understand casting integer into an address is not that intuitive as casting float, double or integer among themselves.
