HAL_RTCEx_BKUPWrite problem
Mohammad A
Senior
Posted on October 26, 2017 at 22:21
There seems to be a problem in HAL_RTCEx_BKUPWrite which is available in CubeF1 1.6.0 package.
void HAL_RTCEx_BKUPWrite(RTC_HandleTypeDef *hrtc, uint32_t BackupRegister, uint32_t Data)
 uint32_t tmp = 0U;
 /* Prevent unused argument(s) compilation warning */
 UNUSED(hrtc);
 /* Check the parameters */
 assert_param(IS_RTC_BKP(BackupRegister));
 tmp = (uint32_t)BKP_BASE;
 tmp += (BackupRegister * 4U);
 *(__IO uint32_t *) tmp = (Data & BKP_DR1_D);
it's not clear if this function is capable of writing 32 bit variables or not, because Data is uint32_t but then it ANDs Data to cut its least significant 16 bits.
It may confuse the user.
#rtc #cube #hal #bug
0 REPLIES 0
