HAL Library for Eeprom emulation
le_tan_phuc
Posted on June 27, 2015 at 06:17
Hi everybody, do we have any update on eeprom emulation library for HAL and CubeMX because the one in ST's site is still the old library for std_periph library ?
#hal-eeprom-emulation
3 REPLIES 3
Posted on June 28, 2015 at 03:27
Consider if there are more effective alternatives, because there probably are.
le_tan_phuc
Posted on June 28, 2015 at 07:35
Hi Clive, what do you mean ? 🙂
Posted on June 29, 2015 at 19:26
Learn how to use FLASH, OTP or Battery backed SRAM to store you're configuration and control information, ultimately it will make for a better solution.
EEPROM Emulation hides implementation details that will almost certainly break your design, use or performance requirements over your product's life.
