2015-06-26 09:17 PM
Hi everybody, do we have any update on eeprom emulation library for HAL and CubeMX because the one in ST's site is still the old library for std_periph library ?
#hal-eeprom-emulation2015-06-27 06:27 PM
Consider if there are more effective alternatives, because there probably are.
2015-06-27 10:35 PM
Hi Clive, what do you mean ? 🙂
2015-06-29 10:26 AM
Learn how to use FLASH, OTP or Battery backed SRAM to store you're configuration and control information, ultimately it will make for a better solution.EEPROM Emulation hides implementation details that will almost certainly break your design, use or performance requirements over your product's life.
