Getting data from SAI interface (microphone array)
erysv
Hi. I want to make microphone array with 16 ICS-52000 microphones connected to STM32L476RG. I made 16 PCB's and now I want to test each microphone and display some data in console just to see if they just work properly. Below is my SAI config:
ICS-52000 MEMS mics have TDM interface wirh 24bit data.
First time using SAI interface and it's a little bit confusing to me. I've tried to use HAL_SAI_Receive() function to get data, and store it in uint8_t data variable, but it didn't work.
How to do it properly?
Thanks for help!
Pierre_Paris
Hello @erysv,
Here are some remark to help you :
  • Have you consider the stm32CubeL4 package and example code ?
  • For your first time, you can also consult the "Getting started" wiki article found here.
  • Have you consider the chapter 43 : SAI of the RM0351?
Best Regards,
Pierre
Thank you for your reply,
I'll check this, because I had problem with finding examples that use SAI.
