DMA buffer position
T J
Lead
In the M0 I used this code to get the current pointer position
    U1RxBufferPtrIN =  U1RxBufSize - huart2.hdmarx->Instance->CNDTR;
but on the H7 this register is not available.
How can I find the current Rx pointer position from the Uart DMA controller ?
1 REPLY 1
T J
Lead
U1RxBufferPtrIN = U1RxBufSize - __HAL_DMA_GET_COUNTER(huart7.hdmarx);
this works !
but how to work the syntax of direct access ?
this does not compile ??
U1RxBufferPtrIN = U1RxBufSize - huart7.hdmarx->Instance.NDTR;
