CubeMX V4.14 Nucleo STM32f446re USB Problem
Sidlauskas.David
Posted on April 04, 2016 at 04:20
Using CubeMX I've built a simple USB FS device CDC project targeted to the Nucleo 64 STM32f446 board. When I run the generated code, DP is never even pulled high so USB doesn't even get started.
I loaded the USB VCP demo project for the EVAL board into the Nucleo and it starts up OK so I think the hardware is good.
Does anyone know of problems with CubeMX generating USB code for Nucleo F446RE's?
Thanks,
Dave
#device #usb #cdc
11 REPLIES 11
Posted on April 11, 2018 at 17:06
Hi
Leschenko.Vladislav
Did you solve your issues? Can you share progress if some?
Thanks in advance for helping tocomplete this thread.
Regards.
Cyril
Posted on May 04, 2018 at 14:38
Hi
Leschenko.Vladislav
Regards.
Cyril
