Albi G.
Comparators vs DWT
  • April 25, 2020
  • 1 reply
  • 801 views
Hi guys,
i just wanted to mention that there is a ****** in the header files.
I am using an STM32G474:
Just an example - stm32g474xx.h defines
#define COMP3 ((COMP_TypeDef *) COMP3_BASE)
And core_cm4.h uses
 __IOM uint32_t COMP3; /*!< Offset: 0x050 (R/W) Comparator Register 3 */
as part of DWT_Type.
Same applies to COMP2 and so on.
Good luck fixing this. Basically you have to rename the comparators.
1 reply
Amel NASRI
Hi @Albi G.​ ,
Thanks for raising this issue. It is reported internally.
-Amel
To give better visibility on the answered topics, please click on "Best Answer" on the reply which solved your issue or answered your question.
