2025-10-06 2:55 AM - last edited on 2025-10-21 4:19 AM by Amel NASRI
I am using STM32L476JE. I wish to use STL api to test 128kb of RAM as startup test for my device. I have come across some example codes but there seems to be confusion around the subsets.
If possible can you share an example code snippet for the same.
I have some doubts listed below:
1. Which method will be efficient to test 128 kb (since memory is large), is it advisable to use
