Can we simple send and receive data over Ethernet using STM32H743 without using lwip stack ?
PPate.1029
4 REPLIES 4
The hardware is designed to send/receive 802.3 packets with relative ease.​
berendi
Principal
Yes, but don't expect it to get through any router unless you create proper TCP/IP packets.
should get to all nodes connected to the switch(s)/hub(s) within the "ethernet" segment you have wired together.
Ask simple questions, get simple answers.
Yes, the LWIP stack sits on top of stuff that just sends/receives on the Ethernet, you can remove LWIP and "Just Do It!"(TM)
Akash_k
Can anyone provide the code for the same (sending and receiving packets using STM32H743) without using LWIP. Please recommend the software for testing the same.
