Hi Everyone ! I have a problem with FAT filesystem. Can you help me ?
İbrahim Cenger
Im trying to write a text in SD Card with stm32F746g-disco. So i check for example application and i found one in STM32CubeMx repository. When i try that code it works perfectly . So i tried to do it my own with STM32CubeMx , i selected stm32f746g-disco, set FATFS defines and generated the code. This is my code :
 if(FATFS_LinkDriver(&SD_Driver, SDPath) == 0)
  if (f_mount(&SDFatFs, (TCHAR const *)SDPath, 0) != FR_OK)
   Error_Handler();
  else
   if (f_mkfs((TCHAR const *)SDPath, FS_ANY, 0, workBuffer, sizeof(workBuffer)) != FR_OK)
    Error_Handler();
   else
    if (f_open(&MyFile,/*(TCHAR const*)*/"STM32.TXT", FA_CREATE_ALWAYS | FA_WRITE) != FR_OK)
     Error_Handler();
    else
     f_write(&MyFile,wtext,sizeof(wtext),(void *)&byteswritten);
     f_close(&MyFile);
FATFS_LinkDriver working, f_mount working but in f_mkfs code gives me an error.
do { /* Fill FAT sectors */
n = (nsect > sz_buf) ? sz_buf : nsect;
if (disk_write(pdrv, buf, sect, (UINT)n) != RES_OK) return FR_DISK_ERR;
mem_set(buf, 0, ss);
sect += n; nsect -= n;
} while (nsect);
I followed the code and found that the error was here. disk_write api gives me FR_DISK_ERR.
What can i do ? Can you help me ?
Regards.
İbrahim
0 REPLIES 0
