2016-06-30 11:51 AM
2016-06-30 12:28 PM
I don't use HAL, you're on your own there.
Yes, you can change baud rate, it is important to make sure that any transmitting data has cleared out the buffer first, ie TXE and TC both asserted. It is possible you might have to clear framing errors, not sure overruns would be an issue. I've done this with u-blox parts...
