build issue : undefined reference to `altcp_tls_wrap'
‎2025-02-12 11:35 PM
I have STM32H747I board. using Ethernet, I have connect MQTT on 1883 port successfully. Now I want to connect 8883 port but after configuration, this kind of error occurs also I have included path for the same. can you please check and give me step to resolve this.
Thank you.include path
error
Ethernet
LwIP
STM32H7 Series
‎2025-02-14 12:50 AM
Hello @Himanshuparmar
Could you please provide a test case to reproduce the issue on our side? This will help us assist you more effectively
Saket_Om
‎2025-02-14 1:05 AM
hey,
I have configure FreeRTOS V2, Ethernet and LWIP stack in STM32H747I in M7 core .ioc file.
In Ethernet : use RMII mode, set tx,rx memory map
In FreeRTOS : use stack size and thread
In LWIP : static IP for the ethernet
after code generation.
I have added mqtt code for 1883 port broker connect and it will connect properly and publish data.
for broker on port 8883, I have changed in file name "lwipopts.h"
#define LWIP_ALTCP 1
#define LWIP_ALTCP_TLS 1
after changes in "lwipopts.h" file, I getting erros as mentioned earlier.
ERROR: >> undefined reference to altcp_tls_wrap
for resolve I have manually add path in project build file but the result was same.
please give me how can I use broker on 8883 port for mqtt connection using LWIP stack and what are the configuration.
Thank you,
Himashu Parmar.
‎2025-02-24 5:38 AM
Any Update on my question? Anyone? @Saket_Om
‎2025-02-24 8:26 AM
Hello @Himanshuparmar,
This issue is under inverstigation. We will get back to you as soon as possible.
Thank you for your understanding.
With Regards,
