Build error in CubeIDE.
fatal error: lwipopts.h: No such file or directory
‎2021-10-07 10:38 AM
Hi
I cannot understand why my opt.h file cannot see the lwipopts.h file in the same folder.
Presumably, it must be something to do with the 'Wno-stringop-overflow' warning.
This contains a very long string -
-mcpu=cortex-m7 -std=gnu11 -g3 -DUSE_HAL_DRIVER -DSTM32H743xxDUSE_STM32H7XX_NUCLEO_144_MB1364 -c -I../../../Src -I"D:/halfcontainer/projects/cubeideN/LwIP_HTTP_Server_Netconn_RTOS/SW4STM32/STM32H743ZI_Nucleo/Middlewares/LwIP" -I../../../Drivers.......+ about 200 chars-
Can anyone tell me how to find out whats happening?
Trying to look back at sys_arch.c is a bit frightening! (To me at least)
Thanks,
Chris
18:12:19 **** Incremental Build of configuration Debug for project LwIP_HTTP_Server_Netconn_RTOS ****
make all
arm-none-eabi-gcc -Wno-stringop-overflow "../Middlewares/Third_Party/LwIP/system/OS/sys_arch.c" -mcpu=cortex-m7 -std=gnu11 -g3 -DUSE_HAL_DRIVER -DSTM32H743xx -DUSE_STM32H7XX_NUCLEO_144_MB1364 -c -I../../../Src -I"D:/halfcontainer/projects/cubeideN/LwIP_HTTP_Server_Netconn_RTOS/SW4STM32/STM32H743ZI_Nucleo/Middlewares/LwIP" -I../../../Drivers/CMSIS/Device/ST/STM32H7xx/Include -I../../../Drivers/STM32H7xx_HAL_Driver/Inc -I../../../Drivers/BSP/STM32H7xx_Nucleo -I../../../Drivers/BSP/Components/Common -I../../../Drivers/BSP/Components -I../../../Middlewares/Third_Party/LwIP/src/include -I../../../Middlewares/Third_Party/LwIP/system -I../../../Middlewares/Third_Party/FreeRTOS/Source/portable/GCC/ARM_CM4F -I../../../Middlewares/Third_Party/FreeRTOS/Source -I../../../Middlewares/Third_Party/FreeRTOS/Source/CMSIS_RTOS -I../../../Middlewares/Third_Party/FreeRTOS/Source/include -I../../../Utilities -I../../../Drivers/CMSIS/Include -Os -ffunction-sections -Wall -fstack-usage -MMD -MP -MF"Middlewares/Third_Party/LwIP/system/OS/sys_arch.d" -MT"Middlewares/Third_Party/LwIP/system/OS/sys_arch.o" --specs=nano.specs -mfpu=fpv5-d16 -mfloat-abi=hard -mthumb -o "Middlewares/Third_Party/LwIP/system/OS/sys_arch.o"
In file included from ../../../Middlewares/Third_Party/LwIP/src/include/lwip/debug.h:41,
from ../Middlewares/Third_Party/LwIP/system/OS/sys_arch.c:34:
../../../Middlewares/Third_Party/LwIP/src/include/lwip/opt.h:51:10: fatal error: lwipopts.h: No such file or directory
51 | #include "lwipopts.h"
compilation terminated.
make: *** [Middlewares/Third_Party/LwIP/system/OS/subdir.mk:19: Middlewares/Third_Party/LwIP/system/OS/sys_arch.o] Error 1
"make all" terminated with exit code 2. Build might be incomplete.
18:12:25 Build Failed. 2 errors, 0 warnings. (took 5s.573ms)
- Labels:
Ethernet
STM32H7 Series
‎2021-10-26 3:33 AM
Hello @clock.1166​ ,
Go to Project options ->C/C++ tab->Include paths and add new paths to your include directories.
I advise you to review this FAQ: How to create project for STM32H7 with Ethernet and LwIP stack working.
When your question is answered, please close this topic by choosing Select as Best.
If you still have issues, don't hesitate to come back to the Community.
Imen
Imen
‎2021-10-26 3:33 AM
Imen
Imen
‎2021-11-01 2:03 AM
Hi @clock.1166​ ,
Were you able to resolve the issue you described here?
If yes, it will be interesting to share with us the solution you found and marked the best answer to close this post.
Imen
Imen
‎2021-11-01 2:21 AM
Sorry, I am a bit late in replying. I have a million jobs on at the moment.
I will get back to it soon.
Chris
‎2021-11-17 5:18 AM
Yes Thanks. That did the problem!
