Azure RTOS licensing..
meghasb
Hi
My company wants to use ThreadX, NextX DUO, File X, Azure RTOS and was not clear if we need to pay for licensing when we send the product to market. we are using U5-series ST boards. can some help whether its an open source that ST has provided in the boards or do we need to procure the license for the same.
21 REPLIES 21
Hi haithem,
Thanku, will check and update.
Hi Haithem,
Thanks for the reply,
I am sharing the logs
Also the Chiper suite we are using on both client and server side is same wiz. TLS-ECDHE-RSA-WITH-CHACHA20-POLY1305-SHA256
But in client it fail at fetching, while receiving data from server.
