‎2020-10-07 2:00 AM
I'm Using the Cube Programmer, I get an Error reading the Location 0x1FFF1E80-8B ( unique MCU ID ) on the STM32H750ZB. I can read the Code memory and connect . correctly.
‎2020-10-09 2:48 AM
Because it is not located at 0x1FFF1E80, but at 0x1FF1E800 (see RM0433, pg 3271).
Good luck!
/Peter
‎2020-10-09 2:48 AM
Good luck!
/Peter
‎2020-10-12 1:50 AM
Thanks :see_no_evil_monkey:
