What is the correct recommended pad size for the STM32 in the TFBGA240+25? The Table 135 of the datasheet seems incorrect.
Options
‎2020-02-18 11:18 AM
With a ball size of 0.4mm I would expect a pad size of 0.36mm , but 0.225 mm is in the table.
Labels:
- Labels:
Documentation
STM32H7 Series
3 REPLIES 3
Options
‎2020-02-25 1:25 AM
Hello @CGand.1​ ,
Which H7 Datasheet ? Please point to the latest Datasheet.
Best Regards,
Imen
Imen
Imen
Options
‎2020-02-25 5:38 AM
Options
‎2020-02-25 7:07 AM
Hi @CGand,
You are right, the PCB recommended design rules for TFBGA240+25 (0.8mm) pitch is not correct.
The values should be:
- Pitch : 0.8
- Dpad : 0.400 mm
- DSM : 0.500 mm
- Stencil opening : 0.400mm
I raised this internally for correction in the next STM32H7 datasheets.
Best Regards,
Imen
Imen
Imen
