The SPI1 clock line is not working on the NUCLEO-F334R8 board
mubarrakky
Visitor
I am trying to get the above named board to work with an ILI9341 based display. But it is not working. I took a look at the SPI lines with a logic analyser. I saw that there was no activity on the CLOCK line. I switched to an alternative pin for the CLOCK signal but I did not get any result.
What could be wrong? Please find attached a copy of my project files for you to take a look at.
Thank you.
1 REPLY 1
Andrew Neil
Evangelist III
Have you checked the board's User Manual and/or schematics to see if there is anything else using that pin?
Can you toggle that pin just as a basic GPIO?
Is there any activity on any other line(s) ?
Please post the schematic of how you are connecting the "ILI9341 based display"
https://community.st.com/t5/community-guidelines/how-to-write-your-question-to-maximize-your-chances-to-find-a/ta-p/575228
