2023-02-16 10:25 PM
Currently doing academic research.
There are few descriptions in the specification, how to measure CMRR?
2023-02-22 5:34 AM
Hello @Community member
CMRR is a basic electronic measurement and calculated as the ratio of the differential gain to the common-mode gain. You may refer to AN4586 as an example of an implementation to highlight the importance of having very accurate resistors.
Hope this could be an enhancement to guide you on how to calculate CMRR.
2023-02-22 5:34 AM
2023-02-22 7:24 AM
The most simple way:
Edit: careful, do not connect any signal generator directly to the controller!
In case of testing a "VCC"-supplied device, it's safest to use the output a single-supply-RRIO-opamp which is also supplied with VCC as a signal source
