2020-09-15 08:30 PM
I have installed the drivers of STLink -v3 and Virtual COM. After connecting the computer with a type-a to micro-b usb cube, it can't be found by the computer.
2020-09-15 08:36 PM
Make sure you're using the right USB connector on the board. Try a different cable. Try a different USB port. Reboot.
2020-09-15 09:11 PM
Make sure cable is viable, charging cables won't work.
2020-09-16 04:59 AM
do not use a USB hub...
2020-09-16 06:53 AM
Hubs and docking stations can be problematic
2020-09-17 12:44 AM
My problem have be solved, thank you guys.
2020-09-17 02:47 AM
It is a good idea to tell here what measure had solved your problems. As you maybe profited from others help, maybe that can be of help to others.
2020-09-17 03:48 AM
Silly mistake. I was tried three different usb cabels and they all were charging only cabel by coincidence. So I bought a new cabel that could transmit data then the problem got solved.
