STM32H747i-DISCO embedded STLINK-V3E can't be found by computer.
TZhou.1
I have installed the drivers of STLink -v3 and Virtual COM. After connecting the computer with a type-a to micro-b usb cube, it can't be found by the computer.
7 REPLIES 7
Guru
Make sure you're using the right USB connector on the board. Try a different cable. Try a different USB port. Reboot.
Make sure cable is viable, charging cables won't work.
Nikita91
Lead II
do not use a USB hub...
Hubs and docking stations can be problematic
TZhou.1
My problem have be solved, thank you guys.​
Uwe Bonnes
Principal III
It is a good idea to tell here what measure had solved your problems. As you maybe profited from others help, maybe that can be of help to others.
TZhou.1
Silly mistake. I was tried three different usb cabels and they all were charging only cabel by coincidence. So I bought a new cabel that could transmit data then the problem got solved.
