STM32F407G-DISC1 - Issue with DFU mode
‎2023-10-03 6:48 AM
I am new to STM products. I have a STM32F407G-DISC1 board and would like to demo a flash program update over USB. I am using the STM32CubeProgrammer.
I am using the following to set up the board for DFU: STM32F407G-DISC1/STM32F4DISCOVERY DFU mode · GitHub
Below is a picture of the board with the connections:
When I open the STM32CubeProgrammer it shows DFU not detected.
Any insight as to what I am doing wrong?
Thanks,
Brent
ST boards
STM32F4 Series
‎2023-10-03 12:31 PM
Check NRST solder bridge between ST-LINK and F407 is disconnected.
Perhaps also power the North USB connector, you want the 8 MHz MCO clock from the ST-LINK for the F4 USB to function
‎2023-10-04 4:15 AM
Hello @BAW ,
Could you please refer to How can I use STM32CubeProgrammer to access the US... - STMicroelectronics Community and check your hardware connection.
I hope this help you to solve the issue.
Thank you.
Kaouthar
‎2023-10-09 11:44 AM
Thank you both for the information and suggestions.
Looking in the AN2606 Application note, I needed Pattern 1 to activate the bootloader.
I needed to pull Boot1 to ground. Before I was only jumping Boot0 to VCC.
Thanks again for the help.
