STM32F407 USART receive, When change baud rate not working
Tato
Hello.
I'm using STM32F407, use usart3 set DMA setting baud rate 9600 and use receive
void HAL_UARTEx_RxEventCallback(UART_HandleTypeDef *huart, uint16_t Size)
if (huart->Instance == USART3) {
HAL_UARTEx_ReceiveToIdle_DMA(&huart3, RxBuff, Size);
__HAL_DMA_DISABLE_IT(&hdma_usart3_rx, DMA_IT_HT);
connect to computer using software terminal "HTerm"
Set baud rate 9600 STM32F407 can receive
But i change to other baud rate such as 115200
then i change baud rate 9600 can not receive
Tato
1. Setting baud rate 9600 HTerm is working
2. Setting baud rate 56000 HTerm is working
3. Setting came back  baud rate 9600 HTerm is not working
8 REPLIES 8
Check if you have any sticky errors in the status register that need clearing.
ie noise, framing, parity, overrun, etc
I'm Setting USART3 below
static void MX_USART3_UART_Init(void)
huart3.Instance = USART3;
huart3.Init.BaudRate = 9600;
huart3.Init.WordLength = UART_WORDLENGTH_8B;
huart3.Init.StopBits = UART_STOPBITS_1;
huart3.Init.Parity = UART_PARITY_NONE;
huart3.Init.Mode = UART_MODE_TX_RX;
huart3.Init.HwFlowCtl = UART_HWCONTROL_NONE;
huart3.Init.OverSampling = UART_OVERSAMPLING_16;
if (HAL_UART_Init(&huart3) != HAL_OK)
Error_Handler();
I ever clearing below
"__HAL_UART_CLEAR_PEFLAG(&huart3);"
"__HAL_UART_CLEAR_FEFLAG(&huart3);"
"__HAL_UART_CLEAR_NEFLAG(&huart3);"
"__HAL_UART_CLEAR_OREFLAG(&huart3);"
"__HAL_DMA_DISABLE_IT(&hdma_usart3_rx, DMA_IT_HT);"
"__HAL_UART_CLEAR_FLAG(&huart3, UART_IT_IDLE);"
"__HAL_UART_ENABLE_IT(&huart3, UART_IT_RXNE);"
How do you change baud rate?
Read out content of UART registers for "working" and "not working" cases, and compare/post.
Tato
Thank you.
Thank you
Tato
Anyone help me ?
You've marked your post of ‎2024-01-14 05:16 PM as the Solution - did you not mean to do that?
