2024-04-17 12:57 AM
I ty to configure the clock setup of stm32f407 board using registers .
But I am not getting the values of Registers in the SFR while debugging.
Since I am enabling the GPIOD in the AHB1ENR registers but still I am not getting the value during the debug.
2024-04-17 12:58 AM
2024-04-17 1:00 AM - edited 2024-04-17 1:03 AM
Try using CubeMX to generate the setup you require, then extract the register values from that.
Please use this button to properly post source code:
2024-04-17 1:09 AM
#include "Mcu.h"
#include"stm32f407xx.h"
int main()
Mcu_Init(&Mcu_ConfigSet[0]);
Mcu_InitClock(0);
while(1)
#include <Mcu_Internal.h>
PwrConfigType PWR_ConfigSet[1] =
/*PwrCRConfgVal*/
VOS_SCALE_1 ,
FPDS_NOT_POWER_DOWN ,
DBP_DISABLED,
PLS20V ,
PVDE_DISABLED ,
PDDS_STOP_MODE ,
LPDS_STOP_MODE,
/*PwrCSRConfgVal*/
BRE_DISABLED ,
EWUP_NOT_WAKEUP,
FLASHConfigType FLASH_ConfigSet[1]=
/*FLASHACRConfgVal*/
DCRST_NOT_RESET ,
ICRST_NOT_RESET,
LATENCY_FIVE_STATE,
DCEN_ENABLED,
ICEN_ENABLED,
PRFTEN_ENABLED,
McuClockConfigType Mcu_ClockConfigSet[1] =
/*Mcu_ClockConfigSet-1*/
/*McuCRConfgVal*/
/*HSION */
HSION_OFF,
/*HSITRIM */
HSITRIM,
/*HSEON */
HSE_ON,
/*HSEBYP */
HSEBYP_OFF,
/*CSSON */
CSS_OFF,
/*PLLON */
PLL_ON,
/*PLLI2SON */
PLLI2S_OFF,
/*McuPLLCFGRConfgVal*/
/*PLLM*/
PLLM_8,
/*PLLN*/
PLLN_336,
/*PLLP*/
PLLP_2,
/*PLLSRC_HSE*/
PLLSRC_HSE,
/*PLLQ*/
PLLQ_7,
/*McuCFGRConfgVal*/
PRE2_AHB_2,
PRE1_AHB_4,
HRPE_SYSCLK_1,
SW_PLL ,
MCO2_SYSCLK,
MCO2PRE_2 ,
MCO1PRE_2 ,
I2SSRC_PLL ,
MCO1_HSE ,
RTC_PREHSE_1,
/*McuCIRConfgVal*/
PLLI2SRDYIELI_DISABLED,
PLLRDYIELI_DISABLED ,
HSERDYIEI_DISABLED ,
HSIRDYIEI_DISABLED ,
LSERDYIEI_DISABLED ,
LSIRDYIEI_DISABLED,
/*McuAHB1ENRConfgVal*/
OTGHSULPIEN_DISABLED,
OTGHSEN_DISABLED,
ETHMACPTPEN_DISABLED,
ETHMACRXEN_DISABLED,
ETHMACTXEN_DISABLED,
ETHMACEN_DISABLED,
DMA2EN_DISABLED,
DMA1EN_DISABLED,
CCMDATARAMEN_DISABLED,
BKPSRAMEN_DISABLED,
CRCEN_DISABLED,
GPIOIEN_DISABLED,
GPIOHEN_DISABLED,
GPIOGEN_DISABLED,
GPIOFEN_DISABLED,
GPIOEEN_DISABLED,
GPIODEN_ENABLED,
GPIOCEN_DISABLED,
GPIOBEN_DISABLED,
GPIOAEN_DISABLED
/*McuAHB2ENRConfgVal*/
OTGFSEN_DISABLED,
RNGEN_DISABLED,
HASHEN_DISABLED,
CRYPEN_DISABLED,
DCMIEN_DISABLED,
/*McuAPB3ENRConfgVal*/
FSMCEN_DISABLED,
/*McuAPB1ENRConfgVal*/
DACEN_DISABLED,
PWREN_ENABLED,
CAN2EN_DISABLED,
CAN1EN_DISABLED,
I2C3EN_DISABLED,
I2C2EN_DISABLED,
I2C1EN_DISABLED,
UART5EN_DISABLED,
UART4EN_DISABLED,
USART3EN_DISABLED,
USART2EN_DISABLED,
SPI3EN_DISABLED,
SPI2EN_DISABLED,
WWDGEN_DISABLED,
TIM14EN_DISABLED,
TIM13EN_DISABLED,
TIM12EN_DISABLED,
TIM7EN_DISABLED,
TIM6EN_DISABLED,
TIM5EN_DISABLED,
TIM4EN_DISABLED,
TIM3EN_DISABLED,
TIM2EN_ENABLED,
/*McuAPB2ENRConfgVal*/
TIM11EN_DISABLED,
TIM10EN_DISABLED,
TIM9EN_DISABLED,
SYSCFGEN_DISABLED,
SPI1EN_DISABLED,
SDIOEN_DISABLED,
ADC3EN_DISABLED,
ADC2EN_DISABLED,
ADC1EN_DISABLED,
USART6EN_DISABLED,
USART1EN_DISABLED,
TIM8EN_DISABLED,
TIM1EN_DISABLED,
/*McuBDCRConfgVal*/
BDRST_RESET_NOTACTIVATED ,
RTCEN_CLOCK_DISABLED ,
RTCSEL_NO ,
LSEBYP_NOT_BYPASSED ,
LSEON_OFF,
/*McuCSRConfgVal*/
LSION_OFF,
/*McuSSCGRConfgVal*/
SSCGEN_DISABLE,
SPREADSEL_CENTRE,
/*McuPLLI2SCFGRConfgVal*/
PLLI2SR2 ,
PLLI2SN0,
Mcu_ConfigType Mcu_ConfigSet[1]=
&PWR_ConfigSet[0],
&Mcu_ClockConfigSet[0],
&FLASH_ConfigSet[0]
This is my code for stm32f407 board for the clock setup using registers. can you look at this and help me with this.
2024-04-17 1:18 AM
You haven't showed the code for your Mcu_InitClock() function.
Again, why not create a working setup using CubeMX - then take the required settings from that?
Then debug your code against the Cube code.
Just on a question of style why:
&PWR_ConfigSet[0],
&FLASH_ConfigSet[0]
instead of just
PWR_ConfigSet,
Mcu_ClockConfigSet,
FLASH_ConfigSet
2024-04-17 2:12 AM
#include "Mcu.h"
#include "Mcu_Config.h"
#include "Mcu_Internal.h"
#include "Mcu_RegTypes.h"
Mcu_ConfigType* Mcu_pConfigPtr = NULL_PTR;
static FUNC(void, MCU_CODE) Mcu_Pwr_Init(VAR( void, AUTOMATIC));
static FUNC(void, MCU_CODE) Mcu_Flash_Init(VAR( void, AUTOMATIC));
static FUNC(void, MCU_CODE) Mcu_AllPeriphralReset(VAR( void, AUTOMATIC));
static FUNC(void, MCU_CODE) Mcu_AHB1Init(VAR( void, AUTOMATIC));
static FUNC(void, MCU_CODE) Mcu_AHB2Init(VAR( void, AUTOMATIC));
static FUNC(void, MCU_CODE) Mcu_AHB3Init(VAR( void, AUTOMATIC));
static FUNC(void, MCU_CODE) Mcu_APB1Init(VAR( void, AUTOMATIC));
static FUNC(void, MCU_CODE) Mcu_APB2Init(VAR( void, AUTOMATIC));
PwrConfigType* LpPwrConfigPtr;
PWR_RegTypedef* LpPWR_Reg = PWR_REGADDRESS;
LpPwrConfigPtr = Mcu_pConfigPtr->PWRConfgSet;
#if(MCU_VOS_SCALE_USED == STD_ON)
LpPWR_Reg->CR |= LpPwrConfigPtr->PwrCRConfgVal.VOS;
#endif
#if(MCU_FPDS_USED == STD_ON)
LpPWR_Reg->CR |= LpPwrConfigPtr->PwrCRConfgVal.FPDS;
#endif
#if(MCU_DBP_USED == STD_ON)
LpPWR_Reg->CR |= LpPwrConfigPtr->PwrCRConfgVal.DBP;
#endif
#if(MCU_PLS_USED == STD_ON)
LpPWR_Reg->CR |= LpPwrConfigPtr->PwrCRConfgVal.PLS;
#endif
#if(MCU_PVDE_USED == STD_ON)
LpPWR_Reg->CR |= LpPwrConfigPtr->PwrCRConfgVal.PVDE;
#endif
#if(MCU_PDDS_USED == STD_ON)
LpPWR_Reg->CR |= LpPwrConfigPtr->PwrCRConfgVal.PDDS;
#endif
#if(MCU_LPDS_USED == STD_ON)
LpPWR_Reg->CR |= LpPwrConfigPtr->PwrCRConfgVal.LPDS;
#endif
#if(MCU_BRE_USED == STD_ON)
LpPWR_Reg->CSR |= LpPwrConfigPtr->PwrCSRConfgVal.BRE;
#endif
#if(MCU_EWUP_USED == STD_ON)
LpPWR_Reg->CSR |= LpPwrConfigPtr->PwrCSRConfgVal.EWUP;
#endif
FLASHConfigType* LpFlashconfigPtr;
FLASH_RegTypedef* LpFLASH_Reg = FLASH_REGADDRESS;
LpFlashconfigPtr = Mcu_pConfigPtr->FlashConfgSet;
#if(MCU_DCRST_USED == STD_ON)
LpFLASH_Reg->ACR |= LpFlashconfigPtr->FLASHACRConfgVal.DCRST;
#endif
LpFLASH_Reg->ACR |= LpFlashconfigPtr->FLASHACRConfgVal.ICRST;
#endif
LpFLASH_Reg->ACR |= LpFlashconfigPtr->FLASHACRConfgVal.LATENCY;
#endif
LpFLASH_Reg->ACR |= LpFlashconfigPtr->FLASHACRConfgVal.DCEN;
#endif
LpFLASH_Reg->ACR |= LpFlashconfigPtr->FLASHACRConfgVal.ICEN;
#endif
LpFLASH_Reg->ACR |= LpFlashconfigPtr->FLASHACRConfgVal.PRFTEN;
#endif
RCC_RegTypedef* LpRCC_Reg = RCC_REGADDRESS;
/*Reset the MCU Peripherals */
LpRCC_Reg->AHB1RSTR =(uint32)(RCC_AHB1RSTR_RESET);
LpRCC_Reg->AHB2RSTR =(uint32)(RCC_AHB2RSTR_RESET);
LpRCC_Reg->AHB3RSTR =(uint32)(RCC_AHB3RSTR_RESET);
LpRCC_Reg->APB1RSTR =(uint32)(RCC_APB1RSTR_RESET);
LpRCC_Reg->APB2RSTR =(uint32)(RCC_APB2RSTR_RESET);
McuClockConfigType* LpMcuClockConfigPtr;
LpMcuClockConfigPtr = Mcu_pConfigPtr->McuClockConfgSet;
#ifdef MCU_USB_OTG_USED
#if(OTGHSULPIEN_USED == STD_ON)
LpRCC_Reg->AHB1ENR |= LpMcuClockConfigPtr->McuAHB1ENRConfgVal.OTGHSULPIEN;
#endif
#if(OTGHSEN_USED == STD_ON)
LpRCC_Reg->AHB1ENR |= LpMcuClockConfigPtr->McuAHB1ENRConfgVal.OTGHSEN;
#endif
#endif
#ifdef MCU_ETHMAC_USED
#if(ETHMACPTPEN_USED == STD_ON)
LpRCC_Reg->AHB1ENR |= LpMcuClockConfigPtr->McuAHB1ENRConfgVal.ETHMACPTPEN;
#endif
#if(ETHMACRXEN_USED == STD_ON)
LpRCC_Reg->AHB1ENR |= LpMcuClockConfigPtr->McuAHB1ENRConfgVal.ETHMACRXEN;
#endif
#if(ETHMACTXEN_USED == STD_ON)
LpRCC_Reg->AHB1ENR |= LpMcuClockConfigPtr->McuAHB1ENRConfgVal.ETHMACTXEN;
#endif
#if(ETHMACEN_USED == STD_ON)
LpRCC_Reg->AHB1ENR |= LpMcuClockConfigPtr->McuAHB1ENRConfgVal.ETHMACEN;
#endif
#endif
#ifdef MCU_DMA_USED
#if(DMA2EN_USED == STD_ON)
LpRCC_Reg->AHB1ENR |= LpMcuClockConfigPtr->McuAHB1ENRConfgVal.DMA2EN;
#endif
LpRCC_Reg->AHB1ENR |= LpMcuClockConfigPtr->McuAHB1ENRConfgVal.DMA1EN;
#endif
#endif
#ifdef MCU_CCM_DATA_RAM_USED
#if(CCMDATARAMEN_USED == STD_ON)
LpRCC_Reg->AHB1ENR |= LpMcuClockConfigPtr->McuAHB1ENRConfgVal.CCMDATARAMEN;
#endif
#endif
#ifdef MCU_BKP_SRAM_USED
#if(BKPSRAMEN_USED == STD_ON)
LpRCC_Reg->AHB1ENR |= LpMcuClockConfigPtr->McuAHB1ENRConfgVal.BKPSRAMEN;
#endif
#endif
#ifdef MCU_CRC_USED
#if(CRCEN_USED == STD_ON)
LpRCC_Reg->AHB1ENR |= LpMcuClockConfigPtr->McuAHB1ENRConfgVal.CRCEN;
#endif
#endif
#ifdef MCU_GPIO_USED
#if(GPIOIEN_USED == STD_ON)
LpRCC_Reg->AHB1ENR |= LpMcuClockConfigPtr->McuAHB1ENRConfgVal.GPIOIEN;
#endif
#if(GPIOHEN_USED == STD_ON)
LpRCC_Reg->AHB1ENR |= LpMcuClockConfigPtr->McuAHB1ENRConfgVal.GPIOHEN;
#endif
#if(GPIOGEN_USED == STD_ON)
LpRCC_Reg->AHB1ENR |= LpMcuClockConfigPtr->McuAHB1ENRConfgVal.GPIOGEN;
#endif
#if(GPIOFEN_USED == STD_ON)
LpRCC_Reg->AHB1ENR |= LpMcuClockConfigPtr->McuAHB1ENRConfgVal.GPIOFEN;
#endif
#if(GPIOEEN_USED == STD_ON)
LpRCC_Reg->AHB1ENR |= LpMcuClockConfigPtr->McuAHB1ENRConfgVal.GPIOEEN;
#endif
#if(GPIODEN_USED == STD_ON)
LpRCC_Reg->AHB1ENR |= LpMcuClockConfigPtr->McuAHB1ENRConfgVal.GPIODEN;
#endif
#if(GPIOCEN_USED == STD_ON)
LpRCC_Reg->AHB1ENR |= LpMcuClockConfigPtr->McuAHB1ENRConfgVal.GPIOCEN;
#endif
#if(GPIOBEN_USED == STD_ON)
LpRCC_Reg->AHB1ENR |= LpMcuClockConfigPtr->McuAHB1ENRConfgVal.GPIOBEN;
#endif
#if(GPIOAEN_USED == STD_ON)
LpRCC_Reg->AHB1ENR |= LpMcuClockConfigPtr->McuAHB1ENRConfgVal.GPIOAEN;
#endif
#endif
#if(OTGFSEN_USED == STD_ON)
LpRCC_Reg->AHB2ENR |= LpMcuClockConfigPtr->McuAHB2ENRConfgVal.OTGFSEN;
#endif
#if(RNGEN_USED == STD_ON)
LpRCC_Reg->AHB2ENR |= LpMcuClockConfigPtr->McuAHB2ENRConfgVal.RNGEN;
#endif
#if(HASHEN_USED == STD_ON)
LpRCC_Reg->AHB2ENR |= LpMcuClockConfigPtr->McuAHB2ENRConfgVal.HASHEN;
#endif
#if(CRYPEN_USED == STD_ON)
LpRCC_Reg->AHB2ENR |= LpMcuClockConfigPtr->McuAHB2ENRConfgVal.CRYPEN;
#endif
#if(DCMIEN_USED == STD_ON)
LpRCC_Reg->AHB2ENR |= LpMcuClockConfigPtr->McuAHB2ENRConfgVal.DCMIEN;
#endif
/*McuAHB3ENRConfgVal*/
LpRCC_Reg->AHB3ENR |= LpMcuClockConfigPtr->McuAHB3ENRConfgVal.FSMCEN;
#endif
#ifdef MCU_DAC_USED
#if(DACEN_USED == STD_ON)
LpRCC_Reg->APB1ENR |= LpMcuClockConfigPtr->McuAPB1ENRConfgVal.DACEN;
#endif
#endif
#ifdef MCU_PWR_USED
#if(PWREN_USED == STD_ON)
LpRCC_Reg->APB1ENR |= LpMcuClockConfigPtr->McuAPB1ENRConfgVal.PWREN;
#endif
#endif
#ifdef MCU_CAN_USED
#if(CAN2EN_USED == STD_ON)
LpRCC_Reg->APB1ENR |= LpMcuClockConfigPtr->McuAPB1ENRConfgVal.CAN2EN;
#endif
#if(CAN1EN_USED == STD_ON)
LpRCC_Reg->APB1ENR |= LpMcuClockConfigPtr->McuAPB1ENRConfgVal.CAN1EN;
#endif
#endif
#ifdef MCU_I2C_USED
#if(I2C3EN_USED == STD_ON)
LpRCC_Reg->APB1ENR |= LpMcuClockConfigPtr->McuAPB1ENRConfgVal.I2C3EN;
#endif
#if(I2C2EN_USED == STD_ON)
LpRCC_Reg->APB1ENR |= LpMcuClockConfigPtr->McuAPB1ENRConfgVal.I2C2EN;
#endif
#if(I2C1EN_USED == STD_ON)
LpRCC_Reg->APB1ENR |= LpMcuClockConfigPtr->McuAPB1ENRConfgVal.I2C1EN;
#endif
#endif
#ifdef MCU_UART_USED
#if(UART5EN_USED == STD_ON)
LpRCC_Reg->APB1ENR |= LpMcuClockConfigPtr->McuAPB1ENRConfgVal.UART5EN;
#endif
#if(UART4EN_USED == STD_ON)
LpRCC_Reg->APB1ENR |= LpMcuClockConfigPtr->McuAPB1ENRConfgVal.UART4EN;
#endif
#endif
#ifdef MCU_USART_USED
#if(USART3EN_USED == STD_ON)
LpRCC_Reg->APB1ENR |= LpMcuClockConfigPtr->McuAPB1ENRConfgVal.USART3EN;
#endif
#if(USART2EN_USED == STD_ON)
LpRCC_Reg->APB1ENR |= LpMcuClockConfigPtr->McuAPB1ENRConfgVal.USART2EN;
#endif
#endif
#ifdef MCU_SPI_USED
#if(SPI3EN_USED == STD_ON)
LpRCC_Reg->APB1ENR |= LpMcuClockConfigPtr->McuAPB1ENRConfgVal.SPI3EN;
#endif
#if(SPI2EN_USED == STD_ON)
LpRCC_Reg->APB1ENR |= LpMcuClockConfigPtr->McuAPB1ENRConfgVal.SPI2EN;
#endif
#endif
#if(WWDGEN_USED == STD_ON)
LpRCC_Reg->APB1ENR |= LpMcuClockConfigPtr->McuAPB1ENRConfgVal.WWDGEN;
#endif
#ifdef MCU_TIM_USED
#if(TIM14EN_USED == STD_ON)
#endif
#if(TIM13EN_USED == STD_ON)
LpRCC_Reg->APB1ENR |= LpMcuClockConfigPtr->McuAPB1ENRConfgVal.TIM13EN;
#endif
#if(TIM12EN_USED == STD_ON)
LpRCC_Reg->APB1ENR |= LpMcuClockConfigPtr->McuAPB1ENRConfgVal.TIM12EN;
#endif
#if(TIM7EN_USED == STD_ON)
LpRCC_Reg->APB1ENR |= LpMcuClockConfigPtr->McuAPB1ENRConfgVal.TIM7EN;
#endif
#if(TIM6EN_USED == STD_ON)
LpRCC_Reg->APB1ENR |= LpMcuClockConfigPtr->McuAPB1ENRConfgVal.TIM6EN;
#endif
#if(TIM5EN_USED == STD_ON)
LpRCC_Reg->APB1ENR |= LpMcuClockConfigPtr->McuAPB1ENRConfgVal.TIM5EN;
#endif
#if(TIM4EN_USED == STD_ON)
LpRCC_Reg->APB1ENR |= LpMcuClockConfigPtr->McuAPB1ENRConfgVal.TIM4EN;
#endif
#if(TIM3EN_USED == STD_ON)
LpRCC_Reg->APB1ENR |= LpMcuClockConfigPtr->McuAPB1ENRConfgVal.TIM3EN;
#endif
#if(TIM2EN_USED == STD_ON)
LpRCC_Reg->APB1ENR |= LpMcuClockConfigPtr->McuAPB1ENRConfgVal.TIM2EN;
#endif
#endif
#ifdef MCU_TIM_USED
#if(TIM11EN_USED == STD_ON)
LpRCC_Reg->APB2ENR |= LpMcuClockConfigPtr->McuAPB2ENRConfgVal.TIM11EN;
#endif
#if(TIM10EN_USED == STD_ON)
LpRCC_Reg->APB2ENR |= LpMcuClockConfigPtr->McuAPB2ENRConfgVal.TIM10EN;
#endif
#if(TIM9EN_USED == STD_ON)
LpRCC_Reg->APB2ENR |= LpMcuClockConfigPtr->McuAPB2ENRConfgVal.TIM9EN;
#endif
#endif
#if(SYSCFGEN_USED == STD_ON)
LpRCC_Reg->APB2ENR |= LpMcuClockConfigPtr->McuAPB2ENRConfgVal.SYSCFGEN;
#endif
#if(SPI1EN_USED == STD_ON)
LpRCC_Reg->APB2ENR |= LpMcuClockConfigPtr->McuAPB2ENRConfgVal.SPI1EN;
#endif
LpRCC_Reg->APB2ENR |= LpMcuClockConfigPtr->McuAPB2ENRConfgVal.SDIOEN;
#endif
#ifdef MCU_ADC_USED
#if(ADC3EN_USED == STD_ON)
LpRCC_Reg->APB2ENR |= LpMcuClockConfigPtr->McuAPB2ENRConfgVal.ADC3EN;
#endif
LpRCC_Reg->APB2ENR |= LpMcuClockConfigPtr->McuAPB2ENRConfgVal.ADC2EN;
#endif
LpRCC_Reg->APB2ENR |= LpMcuClockConfigPtr->McuAPB2ENRConfgVal.ADC1EN;
#endif
#endif
#if(USART6EN_USED == STD_ON)
LpRCC_Reg->APB2ENR |= LpMcuClockConfigPtr->McuAPB2ENRConfgVal.USART6EN;
#endif
#if(USART5EN_USED == STD_ON)
LpRCC_Reg->APB2ENR |= LpMcuClockConfigPtr->McuAPB2ENRConfgVal.USART1EN;
#endif
#endif
#ifdef MCU_TIM_USED
#if(TIM8EN_USED == STD_ON)
LpRCC_Reg->APB2ENR |= LpMcuClockConfigPtr->McuAPB2ENRConfgVal.TIM8EN;
#endif
#if(TIM1EN_USED == STD_ON)
LpRCC_Reg->APB2ENR |= LpMcuClockConfigPtr->McuAPB2ENRConfgVal.TIM1EN;
#endif
#endif
FUNC(void, MCU_CODE) Mcu_Init( Mcu_ConfigType* pConfigPtr)
Mcu_pConfigPtr = pConfigPtr;
Mcu_Pwr_Init();
Mcu_Flash_Init();
Mcu_AllPeriphralReset();
Mcu_AHB1Init();
Mcu_AHB2Init();
Mcu_AHB3Init();
Mcu_APB1Init();
Mcu_APB2Init();
FUNC( Std_ReturnType, MCU_CODE) Mcu_InitClock( VAR( uint8, AUTOMATIC) ClockSetting)
//uint32 LddHSERdyBitVal = (uint32)0x00000000UL;
LpRCC_Reg->CR |= LpMcuClockConfigPtr->McuCRConfgVal.HSEON;
while(!LpRCC_Reg->CR)
LpRCC_Reg->CR |= LpMcuClockConfigPtr->McuCRConfgVal.PLLON;
LpRCC_Reg->PLLCFGR |= LpMcuClockConfigPtr->McuPLLCFGRConfgVal.PLLM;
LpRCC_Reg->PLLCFGR |= LpMcuClockConfigPtr->McuPLLCFGRConfgVal.PLLN;
LpRCC_Reg->PLLCFGR |= LpMcuClockConfigPtr->McuPLLCFGRConfgVal.PLLP;
LpRCC_Reg->PLLCFGR |= LpMcuClockConfigPtr->McuPLLCFGRConfgVal.PLLSRC;
LpRCC_Reg->PLLCFGR |= LpMcuClockConfigPtr->McuPLLCFGRConfgVal.PLLQ;
LpRCC_Reg->CFGR |= LpMcuClockConfigPtr->McuCFGRConfgVal.HPRE;
LpRCC_Reg->CFGR |= LpMcuClockConfigPtr->McuCFGRConfgVal.PPRE1;
LpRCC_Reg->CFGR |= LpMcuClockConfigPtr->McuCFGRConfgVal.PPRE2;
LpRCC_Reg->CFGR |= LpMcuClockConfigPtr->McuCFGRConfgVal.SW;
LpRCC_Reg->CFGR |= LpMcuClockConfigPtr->McuCFGRConfgVal.MCO2;
LpRCC_Reg->CFGR |= LpMcuClockConfigPtr->McuCFGRConfgVal.MCO2PRE;
LpRCC_Reg->CFGR |= LpMcuClockConfigPtr->McuCFGRConfgVal.MCO1PRE;
LpRCC_Reg->CFGR |= LpMcuClockConfigPtr->McuCFGRConfgVal.I2SSRC;
LpRCC_Reg->CFGR |= LpMcuClockConfigPtr->McuCFGRConfgVal.MCO1;
LpRCC_Reg->CFGR |= LpMcuClockConfigPtr->McuCFGRConfgVal.RTCPRE;
LpRCC_Reg->CIR|=LpMcuClockConfigPtr->McuCIRConfgVal.PLLI2SRDYIE;
LpRCC_Reg->CIR|=LpMcuClockConfigPtr->McuCIRConfgVal.PLLRDYIE;
LpRCC_Reg->CIR|=LpMcuClockConfigPtr->McuCIRConfgVal.HSERDYIE;
LpRCC_Reg->CIR|=LpMcuClockConfigPtr->McuCIRConfgVal.HSIRDYIE;
LpRCC_Reg->CIR|=LpMcuClockConfigPtr->McuCIRConfgVal.LSERDYIE;
LpRCC_Reg->CIR|=LpMcuClockConfigPtr->McuCIRConfgVal.LSIRDYIE;
#if 0
LpRCC_Reg->BDCR = LpMcuClockConfigPtr->McuBDCRConfgVal.BDRST;
LpRCC_Reg->BDCR = LpMcuClockConfigPtr->McuBDCRConfgVal.RTCEN;
LpRCC_Reg->BDCR = LpMcuClockConfigPtr->McuBDCRConfgVal.RTCSEL;
LpRCC_Reg->BDCR = LpMcuClockConfigPtr->McuBDCRConfgVal.LSEBYP;
LpRCC_Reg->BDCR = LpMcuClockConfigPtr->McuBDCRConfgVal.LSEON;
LpRCC_Reg->CSR = LpMcuClockConfigPtr->McuCSRConfgVal.LSION;
LpRCC_Reg->SSCGR = LpMcuClockConfigPtr->McuSSCGRConfgVal.SSCGEN;
LpRCC_Reg->SSCGR = LpMcuClockConfigPtr->McuSSCGRConfgVal.SPREADSEL;
LpRCC_Reg->SSCGR = LpMcuClockConfigPtr->McuSSCGRConfgVal.INCSTEP;
LpRCC_Reg->SSCGR = LpMcuClockConfigPtr->McuSSCGRConfgVal.MODPER;
LpRCC_Reg->PLLI2SCFGR = LpMcuClockConfigPtr->McuPLLI2SCFGRConfgVal.PLLI2SR;
LpRCC_Reg->PLLI2SCFGR = LpMcuClockConfigPtr->McuPLLI2SCFGRConfgVal.PLLI2SN;
#endif
return E_OK;
FUNC(Mcu_ResetType, MCU_CODE) Mcu_GetResetReason(VAR( void, AUTOMATIC))
VAR(Mcu_ResetType, AUTOMATIC) eResetReason;
eResetReason = (uint32)LpRCC_Reg->CSR;
return (Mcu_ResetType)eResetReason;
Here is my mcu_init and mcu_initclock
2024-04-17 2:23 AM
Not sure that all these partial writes (read-modify-writes) are a good idea?
Why not make it just a single write, with the value you require?
LpRCC_Reg->PLLCFGR = LpMcuClockConfigPtr->McuPLLCFGRConfgVal.PLLM |
LpMcuClockConfigPtr->McuPLLCFGRConfgVal.PLLN |
LpMcuClockConfigPtr->McuPLLCFGRConfgVal.PLLP |
LpMcuClockConfigPtr->McuPLLCFGRConfgVal.PLLSRC |
etc.
Or could you not just make you McuPLLCFGRConfgVal directly compatible with the register, then do
LpRCC_Reg->PLLCFGR = LpMcuClockConfigPtr->McuPLLCFGRConfgVal;
2024-04-17 2:30 AM
Presumably FUNC, MCU_CODE, VAR, and AUTOMATIC are all macros here?
What do they do?
2024-04-17 3:30 AM
I am just following the autosar standards here. I am enabling the PWREN register of APB1, but the ETHMACPTEN register got updated in the SFRs window. Could you please help me out.
