[Solved] Hi, I'm working with STM32F103C8T6. When I try to debug, it appers the window "No ST-LinkDetected! Please connect ST-Link and restart the debug session".
I tried to modify debug configuration, but I can't debug my project. Can you help me?
‎2020-10-20 09:30 AM
‎2020-12-07 07:58 AM
Thank you for your advice.
The software doesn't recognize the device, the connection is possible only in OTA mode, and I can't update the firmware.
I have a question: when I use STM32CubeProgrammer, to program the device I need another programmer, or it's enough to connect the device to USB port?
‎2020-12-08 05:09 AM
Hello
From AN2606 boot loader can be called only from USART1 for F103C8
The USB of the module is connected to a USB to Serial chip (eg ch340) The serial side (TX RX ) is connected to MCU (PA10 and PA9 pins)
Normaly the device can be programmed (BOOT0 set to 3.3v and reset {POR or by NRST})
When connect to STM32CubeProggramer via usart mode , Check the option bytes if read protected etc. Uncheck theese otions or mass erase chip before you try to program. (PM0075 par 2.4.1 )
‎2020-12-08 05:18 AM
Use the COM port the device creates and use STM32 Cube Programmer in UART mode​.
The BOOT0 jumper needs to be high to run the ROM based system loader.​
Does the board come with a schematic or instructions? Please link to those or attach.​
‎2020-12-08 05:38 AM
‎2020-12-08 08:50 AM
NOYITO USB 10-Channel 12-Bit AD Data Acquisition Module STM32 UART Communication USB to Serial Chip CH340 ADC Module
The viewer was annoying, so grabbed and attached at best resolution I could.
‎2020-12-10 09:15 AM
Hello, I managed to solve my problem.
I've used a USB to Serial chip connected to MCU, BOOT0 connected to 3V3, and STM32CubeProgrammer in the UART mode; I've downloaded the .bin file of my project and I've programmed my device. Now it works correctly.
If there's a mistake in this solution, please tell me.
Thank you very much for helping me.
- « Previous
- 1
- 2
- Next »
