RED LED On due to unknown reason!
‎2025-04-29 11:41 PM - last edited on ‎2025-04-30 1:18 AM by Andrew Neil
I am using STM32F767ZI board for my projects. But due to some unknown reason, the RED led is turned ON in my nucleo board. I am sharing my code along. The code is very simple and I enabled only a single GPIO to be output. Please let me know my mistake! Where am I going wrong. What is my issue.! Also i haven't enable any GPIO that concerns RED Led. Please let me know the answer!
Thanks!
STM32F7 Series
‎2025-04-30 12:08 AM - edited ‎2025-04-30 12:14 AM
@vbk22398 wrote:I am using STM32F767ZI board for my projects.
Do you mean the NUCLEO-F767ZI ?
https://www.st.com/en/evaluation-tools/nucleo-f767zi.html
@vbk22398 wrote:the RED led is turned ON
You mean LD3 ?
@vbk22398 wrote:due to some unknown reason,
Have you tried stepping through your code in the debugger to see exactly when it comes on?
PS:
You can download the schematics from the 'CAD Resources' Tab on the board's Product Page:
https://www.st.com/en/evaluation-tools/nucleo-f767zi.html#cad-resources
‎2025-04-30 12:19 AM
Which LED do you mean?
Several LEDs on the Nucleo, and some connected to the on-board ST-Link, some at the power supplies...
‎2025-04-30 12:42 AM
@LCE wrote:Several LEDs on the Nucleo, and some connected to the on-board ST-Link, some at the power supplies...
Indeed.
@vbk22398 here's the full list:
So there's four LEDs which could possibly show red ...
‎2025-04-30 5:10 AM
LD3.
‎2025-04-30 5:11 AM
@Andrew Neil I tried to enter into debug mode but it doesn't start from main, it starts outside main and if i go inside the function, then it opening a function inside the main, whilst the debug is still outside in some random line.!
‎2025-04-30 5:19 AM
Like it ended up in Error_Handler?
Or it's just running some completely different code? Double check build completes and you download correctly.
Perhaps mass erase and confirm LED goes off.
‎2025-04-30 5:59 AM
That sounds like a bigger problem than a LED being unexpectedly on!
Maybe take that as a separate topic ...
