Program is only working in debug mode using ST link
‎2019-09-24 3:17 AM
Hi All,
I am reading data from UART via polling method. I am sending random data on UART pins and reading on terminal. in that case my program is working fine in debug mode but when try to make this work without debug mode or I can say normal program is not working.
I am using stm32f3 discovery board.
Can anyone tell me what I am doing wrong
/* USER CODE BEGIN Header */
* @file : main.c
* @brief : Main program body
* @attention
* <h2><center>© Copyright (c) 2019 STMicroelectronics.
* All rights reserved.</center></h2>
* This software component is licensed by ST under BSD 3-Clause license,
* the "License"; You may not use this file except in compliance with the
* License. You may obtain a copy of the License at:
* opensource.org/licenses/BSD-3-Clause
/* USER CODE END Header */
#include "main.h"
/* Private includes ----------------------------------------------------------*/
/* USER CODE END Includes */
/* USER CODE BEGIN PTD */
/* USER CODE END PTD */
/* USER CODE BEGIN PD */
/* USER CODE END PD */
/* USER CODE BEGIN PM */
/* USER CODE END PM */
UART_HandleTypeDef huart4;
/* USER CODE BEGIN PV */
uint8_t rx[5] = {'H', 'E', 'L', 'L', 'O'};
uint8_t tx[12],rx_index;
uint8_t rx_data[12];
uint8_t tx_data[12];
uint8_t msg_count = 0;
char msg_flag = 0;
uint32_t x1 = 0;
uint8_t response[11] = {'{','[','0','0','0','0','0','0','0',']','}'};
//uint8_t msg_count = 0;
uint8_t msg_c_count = 0;
/* USER CODE END PV */
static void MX_UART4_Init(void);
/* USER CODE BEGIN PFP */
void data_process(uint8_t *);
/* USER CODE END PFP */
/* Private user code ---------------------------------------------------------*/
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
* @brief The application entry point.
* @retval int
int main(void)
/* USER CODE BEGIN 1 */
/* USER CODE END 1 */
HAL_Init();
/* USER CODE BEGIN Init */
/* USER CODE END Init */
SystemClock_Config();
/* USER CODE BEGIN SysInit */
/* USER CODE END SysInit */
MX_GPIO_Init();
MX_UART4_Init();
/* USER CODE BEGIN 2 */
//HAL_FLASH_Unlock();
/* USER CODE END 2 */
/* Infinite loop */
/* USER CODE BEGIN WHILE */
while (1)
/* USER CODE END WHILE */
/* USER CODE BEGIN 3 */
HAL_UART_Receive(&huart4, rx_data, 12, 100);
/*if (rx_data[0] == 'S'){
HAL_UART_Transmit(&huart4, response, 12,10);
HAL_Delay(100);
rx_data[0] = '0';
if (rx_data[0] == '{'){
for(msg_c_count = 0; msg_c_count < 12; msg_c_count++){
tx_data[msg_c_count] = rx_data[msg_c_count];
memset(rx_data,0,sizeof(rx_data));HAL_Delay(10);
msg_flag = 1;
if (msg_flag == 1){
msg_flag = 0;
data_process(tx_data);
memset(tx_data,0,sizeof(tx_data));HAL_Delay(10);
msg_c_count = 0;
msg_count = 0;
/* USER CODE END 3 */
* @brief System Clock Configuration
* @retval None
void SystemClock_Config(void)
RCC_PeriphCLKInitTypeDef PeriphClkInit = {0};
/** Initializes the CPU, AHB and APB busses clocks
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
RCC_OscInitStruct.HSEState = RCC_HSE_ON;
RCC_OscInitStruct.HSEPredivValue = RCC_HSE_PREDIV_DIV1;
RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL9;
Error_Handler();
RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
Error_Handler();
PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_UART4;
PeriphClkInit.Uart4ClockSelection = RCC_UART4CLKSOURCE_PCLK1;
if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit) != HAL_OK)
Error_Handler();
* @brief UART4 Initialization Function
* @param None
* @retval None
/* USER CODE BEGIN UART4_Init 0 */
/* USER CODE END UART4_Init 0 */
/* USER CODE BEGIN UART4_Init 1 */
/* USER CODE END UART4_Init 1 */
huart4.Instance = UART4;
huart4.Init.BaudRate = 115200;
huart4.Init.WordLength = UART_WORDLENGTH_8B;
huart4.Init.StopBits = UART_STOPBITS_1;
huart4.Init.Parity = UART_PARITY_NONE;
huart4.Init.Mode = UART_MODE_TX_RX;
huart4.Init.HwFlowCtl = UART_HWCONTROL_NONE;
huart4.Init.OverSampling = UART_OVERSAMPLING_16;
huart4.Init.OneBitSampling = UART_ONE_BIT_SAMPLE_DISABLE;
huart4.AdvancedInit.AdvFeatureInit = UART_ADVFEATURE_NO_INIT;
if (HAL_UART_Init(&huart4) != HAL_OK)
Error_Handler();
/* USER CODE BEGIN UART4_Init 2 */
/* USER CODE END UART4_Init 2 */
* @brief GPIO Initialization Function
* @param None
* @retval None
/* GPIO Ports Clock Enable */
__HAL_RCC_GPIOC_CLK_ENABLE();
__HAL_RCC_GPIOF_CLK_ENABLE();
__HAL_RCC_GPIOA_CLK_ENABLE();
/* USER CODE BEGIN 4 */
void data_process(uint8_t *arr)
if (arr[0] == '{'){
msg_count = 0;
for (msg_count = 1; msg_count < 9; msg_count++){
if (arr[msg_count+1] != '5'){
if (arr[msg_count+1] == '1'){
response[msg_count+1] = '1';
else if(arr[msg_count+1] == '0'){
response[msg_count+1] = '0';
else{
response[0] = '{';response[1] = '[';response[9] = ']';response[10] = '}';
HAL_UART_Transmit(&huart4, response,sizeof(response),50);
HAL_Delay(100);
x1 = HAL_UART_GetState(&huart4);
memset(response,0,sizeof(response));HAL_Delay(10);
/* USER CODE END 4 */
* @brief This function is executed in case of error occurrence.
* @retval None
void Error_Handler(void)
/* USER CODE BEGIN Error_Handler_Debug */
/* User can add his own implementation to report the HAL error return state */
/* USER CODE END Error_Handler_Debug */
#ifdef USE_FULL_ASSERT
* @brief Reports the name of the source file and the source line number
* where the assert_param error has occurred.
* @param file: pointer to the source file name
* @param line: assert_param error line source number
* @retval None
void assert_failed(char *file, uint32_t line)
/* USER CODE BEGIN 6 */
/* User can add his own implementation to report the file name and line number,
tex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
/* USER CODE END 6 */
#endif /* USE_FULL_ASSERT */
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
ST-Link
STM32F3 Series
‎2019-09-24 3:39 AM
Different code, perhaps by "#ifdef _DEBUG" ?
Different build settings, i.e. code optimization enabled in release mode ?
‎2019-09-24 3:47 AM
which IDE you are using?
‎2019-09-24 3:48 AM
I am using Keil 5
‎2019-09-24 3:56 AM
issue has been t, I was not reseting the controller after firmware download.. Thanks for you help
‎2019-09-24 3:57 AM
check the startup script in debug configuration...
‎2020-10-25 9:32 AM
Same problem I am facing with stm32h7 43, what is its solution?
Please reply
‎2020-10-25 11:46 AM
H7 issues unlikely correlate with F3 ones, a year ago.
Let's keep this on your other thread.
