Nucleof446 UART
‎2024-09-25 1:54 AM - last edited on ‎2024-09-25 3:37 AM by Andrew Neil
Hi
- I am trying to communicate between arm processor and nucleo board through uart
- The processor has a type b usb , to interface with computer.
- For the same usb I am connecting my Nucelo board through usb type B mini and sending the data through it
- When i connect the device to laptop/computer the communication happens, and when i connect nucleo the communication does not happen.
- Im giving both power supply and uart communication from usb cable.
ST boards
STM32F4 Series
‎2024-09-26 2:53 AM - edited ‎2024-09-26 3:02 AM
@harry123 wrote:
- Will the same STM UART transmit receive code that is used for VCP i.e teraterm/putty works for AT91SAM
The whole point of the standard USB device profiles is that the device is completely oblivious to the nature of the host - it neither knows nor cares whether the host is a PC or a Mac or some sort of Linux or whatever.
Similarly the Host is completely oblivious to the nature of the device - it just sees a standard Virtual Serial Port.
So the question is: does your SAM board support a VCP?
You can easily find out by just plugging it in - does a VCP device appear?)
It will probably appear as a /dev/ttyACMx (maybe a /dev/ttyUSBx) ::(:(:(
‎2024-09-25 2:05 AM
So this "ARM processor" has a USB Device connection.
The CN1 USB connector on your Nucleo board is also a USB Device connection:
You cannot connect two USB Devices together - a Device can only connect to a Host.
That's because the computer is a Host.
‎2024-09-25 2:09 AM
What is CN2?
Is that a USB Host port?
‎2024-09-25 2:53 AM - edited ‎2024-09-25 2:53 AM
- YES That USB type A port is used to interface a printer
- and another port USB type is is used to interface with a computer.
- And I want to have communication between Nucleo and Processor ( I have attached pdf of processor) .
‎2024-09-25 3:11 AM - edited ‎2024-09-25 3:38 AM
@harry123 wrote:
- I want to have communication between Nucleo and Processor
The CN1 USB connector on your Nucleo board is a USB Device connection for the Virtual COM Port (VCP) in the ST-Link:
To use that, you must connect it to a USB Host port. That's the way it works.
Instead of using this USB connection, could you use a direct logic-level connection to one of the UARTs on your ARM9 board?
‎2024-09-25 3:36 AM
Does it support a Hub - then you could use it for both the printer and the ST-Link VCP ... ?
‎2024-09-25 3:43 AM
- It is the pin PB4 and PB5 of arm processor which is connected to USB device and Interface is happening through PC/laptop. Like sending the data and receving the data.
- Can I try connecting PB4 and PB5 and GND of arm processor directly to the USART1 pin PA9 and PA10 and GND of my nucleo board through J25(in image)
- Will the logic level be same between both the boards.
- Thank you
‎2024-09-25 3:51 AM
Which "ARM processor" are you talking about? Both the STM32 and the AT91SAM9G45 are ARM processors!
You need to study the board documentation for that.
‎2024-09-25 4:23 AM
AT91SAM9G45 processor.
‎2024-09-25 4:34 AM
There's not enough information in that brief document - you need a more detailed technical manual.
But this Mini6045 board seems to be obsolete and no longer supported - so no idea where you'll find that.
