2025-01-02 4:02 PM
Is the a User Manual available for the Nucleo-N657X0-Q that contains the connector pinouts and jumper settings etc. The document (UM1727) listed on the documentation page https://www.st.com/en/evaluation-tools/nucleo-n657x0-q.html#documentation points to a generic Nucleo document that contains no information specific to the Nucleo-N657X0-Q.
2025-01-03 1:17 AM
Hello @theRat ,
The user manual will be available soon on the ST website. As stated by @filipxsikora , in meantime you can use the schematics.
2025-01-02 5:51 PM
2025-01-03 1:17 AM
Hello @theRat ,
2025-01-03 2:29 AM
Hi @theRat ,
Besides to what was previously said, I confirm that UM3417 dedicated for NUCLEO-N657X0-Q will be available soon on the web.
Meanwhile, you can refer to attached pdf by @RomainR. in NUCLEO-N657X0-Q: failed to start GDB server to know more about jumpers setup.
-Amel
2025-01-05 1:54 PM
I see the UM is now available. Thank for the responses.
